Page 1 of 3 1 2 3
Fresh Magnum 318 is a DOG!---UPDATE #1144975
12/27/11 01:09 PM
12/27/11 01:09 PM
Glendale, AZ
69L78Nova Offline OP
Banned. Forever.
Banned. Forever.
Glendale, AZ
Got the new 318 fired up and running and something seems wrong. It has absolutely no power, sucks gas like a pig, idles kinda rough, and is hard as hell to start when cold. It's a stock piston Magnum 318 with a Summit K6900 cam. It also drags the starter at anything more than 2-3 degrees initial timing. It just feels lazy, and pretty much need to crack the secondaries to take off with traffic. It's as gutless as a 318-2 barrel. It's pulling 16-17 in/hg at 900 rpm. I'm wondering if the chain being off a tooth could be the culprit. I've tried 3 known good carbs and no matter what, it runs like crap. It currently has a box stock 625 Carter on it. I'm going to do a compression test tonight. I'm just hoping the cam isn't too big with the 1.6 rockers. I've run an XE256 in a stock LA318 with great results. The duration @.050" with the Summit cam is small enough, I thought it would be ok. Any thoughts?
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Fresh Magnum 318 is a DOG! [Re: 69L78Nova] #1144976
12/27/11 01:15 PM
12/27/11 01:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Did you degree the cam when you put it in... sounds
like the cam is retarded(put in wrong)
Re: Fresh Magnum 318 is a DOG! [Re: MR_P_BODY] #1144977
12/27/11 01:38 PM
12/27/11 01:38 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
what he said
Re: Fresh Magnum 318 is a DOG! [Re: JohnRR] #1144978
12/27/11 01:50 PM
12/27/11 01:50 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
I didn't degree it, just installed it dot to dot. It's the cam, lifters, pushrods, and timing set out of my old 360. I figured I should add the engine is in my 78 Fury, with headers, 2.5" duals, A500 trans, and 3.55s. So am I correct in assuming the cam isn't too big, and it should be pulling more vacuum than it is?
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: Fresh Magnum 318 is a DOG! [Re: 69L78Nova] #1144979
12/27/11 01:58 PM
12/27/11 01:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If its retarded it will change the vac... is it too
big... I dont think so... but you HAVE TO DEGREE it
plus I'd advance it 4* so you get better low end torque
Re: Fresh Magnum 318 is a DOG! [Re: MR_P_BODY] #1144980
12/27/11 02:21 PM
12/27/11 02:21 PM
You may be able to align the dots in 12 motors and the 13th, or 25th one will bite you. Always take the time to degree them from now on
Re: Fresh Magnum 318 is a DOG! [Re: Cab_Burge] #1144981
12/27/11 02:55 PM
12/27/11 02:55 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
I guess its time to dig the degree wheel out. I do have the offset keyway package as well and adjustable piston stop as well. I have everything to do it. I just never had much confidence when it came to doing that. What better way to learn than to try I guess! I figured it should at least have a decent amount of power for a 318.
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: Fresh Magnum 318 is a DOG! [Re: 69L78Nova] #1144982
12/27/11 04:21 PM
12/27/11 04:21 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
You put a flat tapper cam and lifters into a roller cam block? Do you have lifters that allow for oil through pushrods? Otherwise those rockers on the magnum heads won't get oil. How's the pushrod length? I didn't think that was all interchangeable because of the differences in valvetrain.
**Photobucket sucks**
Re: Fresh Magnum 318 is a DOG! [Re: 70Cuda383] #1144983
12/27/11 04:58 PM
12/27/11 04:58 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
Yes, the Summit lifters do have the oil hole in the plunger. The pushrods are the same 7.650" rods I had in my LA360 with Magnum heads. The rockers are getting oil
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: Fresh Magnum 318 is a DOG! [Re: 69L78Nova] #1144984
12/27/11 05:40 PM
12/27/11 05:40 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
So how did the 360 run? If you re-used the timing set, cam, etc., etc, out of the old motor AND it ran well, unless you screwed something up installing them, I can't believe the timing set would now be a problem.
Re: Fresh Magnum 318 is a DOG! [Re: 6PakBee] #1144985
12/27/11 06:13 PM
12/27/11 06:13 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
The 360 ran great with that setup, considering it had stock dished pistons over .100" in the hole. Pulled this boat into the 14s, but developed a bottom end knock. I had the 318 laying around so I went through it and put it in. The 318 pistons are the stock flat tops, about .050" down. I'm thinking I put the timing set on a tooth off or something. It's gotta be. Everything else is the same, heads, intake, cam/lifters, pushrods, timing set, and carb. I can't think of what else it could be....
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: Fresh Magnum 318 is a DOG! [Re: 6PakBee] #1144986
12/27/11 06:35 PM
12/27/11 06:35 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i would replace that chain, i'm assuming it to is used.
Re: Fresh Magnum 318 is a DOG! [Re: mikemee1331] #1144987
12/27/11 07:00 PM
12/27/11 07:00 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
Yes, it is used, but hardly has any miles on it. I'll pick up a new one when I pull the timing cover
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: Fresh Magnum 318 is a DOG! [Re: 69L78Nova] #1144988
12/27/11 07:42 PM
12/27/11 07:42 PM
Out on a limb but I'm thinking with 16-17 in hg the cam timing is OK and the prob is in the timing: find/confirm exact TDC/set initial at 15 for a start/proper firing order/pickup gap/rotor phasing/good curve, I'm assuming there's no vac leak. yes a compression test will confirm that the long block itself is OK
Re: Fresh Magnum 318 is a DOG! [Re: RapidRobert] #1144989
12/27/11 07:55 PM
12/27/11 07:55 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
good point 'other RR', i didn't even notice the vac number! perhaps too the dizzy is off a tooth which he can check when he does a TDC check.
Re: Fresh Magnum 318 is a DOG! [Re: mikemee1331] #1144990
12/27/11 07:58 PM
12/27/11 07:58 PM
Didn't know if it was noticeable but I still have a hangover from that day
Re: Fresh Magnum 318 is a DOG! [Re: RapidRobert] #1144991
12/27/11 08:16 PM
12/27/11 08:16 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i was clueless. just thought your response funny. i know you've had a in the past. i have too and worse of all, he was right! i have alot of respect for his opinions (and humor)
Re: Fresh Magnum 318 is a DOG! [Re: 69L78Nova] #1144992
12/27/11 08:49 PM
12/27/11 08:49 PM
Wadena MN USA
dustdevil Offline
dustdevil  Offline
Wadena MN USA
start with your basics. dist,firing order, dist advance stuck? build backwards. if your guts are talking to you about that timing chain placement go back to that point. make sure you take the time to degree it to confirm Good Luck BT
Re: Fresh Magnum 318 is a DOG! [Re: dustdevil] #1144993
12/27/11 08:54 PM
12/27/11 08:54 PM
The tipoff that hit me was that it has labored cranking at 2-3 initial
Re: Fresh Magnum 318 is a DOG! [Re: 69L78Nova] #1144994
12/27/11 08:58 PM
12/27/11 08:58 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
1.6 rockers may be giving more lift/duration than needed for that cam.318's historically were dependable.."dog" engines. The best one I had was a 60 phoenix with a 4 bbl from the factory. It would chirp the tires in second but was no speed demon
Page 1 of 3 1 2 3
