Fresh Magnum 318 is a DOG!---UPDATE
#1144975
12/27/11 01:09 PM
12/27/11 01:09 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Got the new 318 fired up and running and something seems wrong. It has absolutely no power, sucks gas like a pig, idles kinda rough, and is hard as hell to start when cold. It's a stock piston Magnum 318 with a Summit K6900 cam. It also drags the starter at anything more than 2-3 degrees initial timing. It just feels lazy, and pretty much need to crack the secondaries to take off with traffic. It's as gutless as a 318-2 barrel. It's pulling 16-17 in/hg at 900 rpm. I'm wondering if the chain being off a tooth could be the culprit. I've tried 3 known good carbs and no matter what, it runs like crap. It currently has a box stock 625 Carter on it. I'm going to do a compression test tonight. I'm just hoping the cam isn't too big with the 1.6 rockers. I've run an XE256 in a stock LA318 with great results. The duration @.050" with the Summit cam is small enough, I thought it would be ok. Any thoughts?
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
Re: Fresh Magnum 318 is a DOG!
[Re: MR_P_BODY]
#1144977
12/27/11 01:38 PM
12/27/11 01:38 PM
Posts: 74,976 U.S.S.A.
JohnRR
U.S.S.A.
Did you degree the cam when you put it in... sounds like the cam is retarded(put in wrong)
[Re: JohnRR]
#1144978
12/27/11 01:50 PM
12/27/11 01:50 PM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I didn't degree it, just installed it dot to dot. It's the cam, lifters, pushrods, and timing set out of my old 360. I figured I should add the engine is in my 78 Fury, with headers, 2.5" duals, A500 trans, and 3.55s. So am I correct in assuming the cam isn't too big, and it should be pulling more vacuum than it is?
[Re: 69L78Nova]
#1144979
12/27/11 01:58 PM
12/27/11 01:58 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If its retarded it will change the vac... is it too big... I dont think so... but you HAVE TO DEGREE it plus I'd advance it 4* so you get better low end torque
[Re: MR_P_BODY]
#1144980
12/27/11 02:21 PM
12/27/11 02:21 PM
Posts: 43,124 Bend,OR USA
Cab_Burge
You may be able to align the dots in 12 motors and the 13th, or 25th one will bite you. Always take the time to degree them from now on
[Re: Cab_Burge]
#1144981
12/27/11 02:55 PM
12/27/11 02:55 PM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I guess its time to dig the degree wheel out. I do have the offset keyway package as well and adjustable piston stop as well. I have everything to do it. I just never had much confidence when it came to doing that. What better way to learn than to try I guess! I figured it should at least have a decent amount of power for a 318.
[Re: 69L78Nova]
#1144982
12/27/11 04:21 PM
12/27/11 04:21 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
You put a flat tapper cam and lifters into a roller cam block? Do you have lifters that allow for oil through pushrods? Otherwise those rockers on the magnum heads won't get oil. How's the pushrod length? I didn't think that was all interchangeable because of the differences in valvetrain.
**Photobucket sucks**
[Re: 70Cuda383]
#1144983
12/27/11 04:58 PM
12/27/11 04:58 PM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Yes, the Summit lifters do have the oil hole in the plunger. The pushrods are the same 7.650" rods I had in my LA360 with Magnum heads. The rockers are getting oil
[Re: 69L78Nova]
#1144984
12/27/11 05:40 PM
12/27/11 05:40 PM
Posts: 10,704 North Dakota
6PakBee
North Dakota
So how did the 360 run? If you re-used the timing set, cam, etc., etc, out of the old motor AND it ran well, unless you screwed something up installing them, I can't believe the timing set would now be a problem.
[Re: 6PakBee]
#1144985
12/27/11 06:13 PM
12/27/11 06:13 PM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
The 360 ran great with that setup, considering it had stock dished pistons over .100" in the hole. Pulled this boat into the 14s, but developed a bottom end knock. I had the 318 laying around so I went through it and put it in. The 318 pistons are the stock flat tops, about .050" down. I'm thinking I put the timing set on a tooth off or something. It's gotta be. Everything else is the same, heads, intake, cam/lifters, pushrods, timing set, and carb. I can't think of what else it could be....
[Re: mikemee1331]
#1144987
12/27/11 07:00 PM
12/27/11 07:00 PM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Yes, it is used, but hardly has any miles on it. I'll pick up a new one when I pull the timing cover
[Re: 69L78Nova]
#1144988
12/27/11 07:42 PM
12/27/11 07:42 PM
RapidRobert
Out on a limb but I'm thinking with 16-17 in hg the cam timing is OK and the prob is in the timing: find/confirm exact TDC/set initial at 15 for a start/proper firing order/pickup gap/rotor phasing/good curve, I'm assuming there's no vac leak. yes a compression test will confirm that the long block itself is OK
[Re: RapidRobert]
#1144989
12/27/11 07:55 PM
12/27/11 07:55 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
good point 'other RR', i didn't even notice the vac number! perhaps too the dizzy is off a tooth which he can check when he does a TDC check.
[Re: RapidRobert]
#1144991
12/27/11 08:16 PM
12/27/11 08:16 PM
mikemee1331
bethlehem pa
Didn't know if it was noticeable but I still have a hangover from that day
i was clueless. just thought your response funny. i know you've had a in the past. i have too and worse of all, he was right! i have alot of respect for his opinions (and humor)
