What's the best valve cover gasket? #114476
09/03/08 08:54 AM
09/03/08 08:54 AM
Spring, Texas
RedFish Offline OP
super street
RedFish  Offline OP
super street
Spring, Texas
I know this has been asked a bunch of times in the past but I never pay attention. At least that's what my wife says. What valve cover gasket can I get to stop the oil leaks. I have a 360 with iron heads and MP aluminum valve covers.
Howard
You don't stop playing games when you get old, You get old when you stop playing games.
Re: What's the best valve cover gasket? [Re: RedFish] #114477
09/03/08 08:59 AM
09/03/08 08:59 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
I like the reusable Mopar Performance gaskets. Haven't had a leak since I started using them and had them off and on a few times.
Re: What's the best valve cover gasket? [Re: MoparforLife] #114478
09/03/08 09:01 AM
09/03/08 09:01 AM
NY usa
540challenger Offline
NY usa
Andanother choice is the new moroso gaskets both can be found at mancinni.
Re: What's the best valve cover gasket? [Re: 540challenger] #114479
09/03/08 09:06 AM
09/03/08 09:06 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
You have a cast-alum VC ? ... you could probably use a USED gasket and make those seal.
The problem is as I have seen it is the standard VC is bent and warped and would leak even-if it was WELDED onto the head.
Re: What's the best valve cover gasket? [Re: MoparforLife] #114480
09/03/08 09:16 AM
09/03/08 09:16 AM
Spring, Texas
RedFish Offline OP
super street
RedFish  Offline OP
super street
Spring, Texas
Don, are those MP gaskets the ones that are metal and rubber?
Re: What's the best valve cover gasket? [Re: RedFish] #114481
09/03/08 09:57 AM
09/03/08 09:57 AM
Upper Midwest
Upper Midwest
Yes: see if this works. Mancini
MOPAR - "A" engine High Performance 5-bolt
Heavy duty ribbed, molded rubber gasket with steel shim reinforcement for added strength. For five-bolt covers (will not fit Magnum engine application)
$20.95
MOP-P5249581
Re: What's the best valve cover gasket? [Re: RedFish] #114482
09/03/08 10:02 AM
09/03/08 10:02 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
On my Challenger T/A,....I like to use the HP Fel-pro....extra thick, pure silicone, Orange in color,....had a set on for about 15 years now,....covers get removed occasionally for lash adjustment,....haven't had a leak yet,.....don't know if these gaskets are still available
Re: What's the best valve cover gasket? [Re: dOoC] #114483
09/05/08 02:05 PM
09/05/08 02:05 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
