Re: Frame paint
[Re: B1arno]
#1144147
01/15/12 03:40 PM
01/15/12 03:40 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
WOW!! That looks ultra strong! Shouldn't have any flex issues! Very clean too! It is going to look great with all the preparation you have done. I am looking forward to seeing it coated. Mark
Re: Frame paint
[Re: Hemi Allstate]
#1144148
01/15/12 08:48 PM
01/15/12 08:48 PM
Posts: 1,039 Redwood City Ca.
B1arno
Redwood City Ca.
Mark
Yeah, it had the main portions of the frame done when I bought the car. I wanted it as a street cruiser so I wasn't overly concerned with the weight. The frame was pretty well done, very square and straight. I put all new suspention under it, body mounts, engine and trans mounts, and new frame horns. I'll post pics when I get it back.
Arno
Re: Frame paint
[Re: Hemi Allstate]
#1144155
02/13/12 11:29 PM
02/13/12 11:29 PM
B1arno
Redwood City Ca.
Looking Good!!! Man those sure are some big rear tires!!! Very nice Arno.
Mark
If I recall correctly your tires will need to be of similar size if you plan on filling those tubs! I got the engine back in today with the flywheel installed but forgot to get new pressure plate bolts. I did start working out the adjustment on the hydraulic T/O bearing. Seems quite straight forward. I should have the entire drivetrain installed this weekend.
