Attaching fiberglass scoop to metal hood #1143528
12/24/11 08:46 PM
12/24/11 08:46 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I have a steel hood on the '69 Barracuda and a fiberglass hemi hood scoop. The scoop isn't high quality and doesn't even have usable mounting tabs to mount it. If you had a glass hemi scoop with no flange or tabs how would you mount it to a steel hood? Duct tape, pipe cleaners, superglue?
I imagine I need to glass in some kind of mounting tabs but didn't know what it would take to ensure it didn't come off at 100+ mph.
Re: Attaching fiberglass scoop to metal hood [Re: VITC_GTX] #1143529
12/24/11 10:05 PM
12/24/11 10:05 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
Well, to make this post short...don't bother doing it, you will be wasting your time and money. It won't last..it will crack and when the hood gets hot, you will see a ghost line where the fiberglass stops and the steel starts. I would advise you just to buy a good quality fiberglass hood.
Re: Attaching fiberglass scoop to metal hood [Re: GLR] #1143530
12/24/11 10:31 PM
12/24/11 10:31 PM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
I agree, mine was cracking all the way around, even before I painted it.
-Daty
Re: Attaching fiberglass scoop to metal hood [Re: GLR] #1143531
12/24/11 10:32 PM
12/24/11 10:32 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
There is some new kind new bonding agent on the market for that.. Seen it on TV. Cant remember what its called tho. Call a auto body/paint store..
I am truckless..
Re: Attaching fiberglass scoop to metal hood [Re: 340SHORTY] #1143532
12/24/11 11:29 PM
12/24/11 11:29 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
My auto body/paint suppler sells 3M and Fuzer make and they both will glue/bond the scoop to the hood...but these products are not compatible with body fillers , so you have to remove all excess glue/bonding material and prime the complete area with epoxy (2-coats) and let dry for 24 hours at 70 deg. , scuff with burgundy scuff pad and clean with cleaner and then apply a good light weight body filler. The main problem is that as soon as the hood gets heat from the engine or being in the sun or both , you will see ghost lines where the steel and the bonding edges are.
Re: Attaching fiberglass scoop to metal hood [Re: GLR] #1143533
12/25/11 12:16 AM
12/25/11 12:16 AM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Glass scoop and metal hood 4 yrs now ,still looks good
Re: Attaching fiberglass scoop to metal hood [Re: VITC_GTX] #1143534
12/25/11 02:49 AM
12/25/11 02:49 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I don't need a seamless fit between the two pieces, just looking for a way to attach it so it doesn't blow off! I'll glass in some "tabs" to bolt it to the hood and I'll just trim it closely so it there is little gap between the two pieces.
