Soda blasting ? will it polish aged aluminum wheels? #1143418
12/24/11 03:46 PM
12/24/11 03:46 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
I'd like to polish these wheels, hopefully not by hand. Will having them soda blasted polish them? I'm not looking for a mirror finish just something brighter than how they look now.
Re: Soda blasting ? will it polish aged aluminum wheels? [Re: NV69B7RR] #1143419
12/24/11 04:08 PM
12/24/11 04:08 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I soda blast aluminum prior to polishing, the best your going to get is an "as cast" finish with soda, I generally tumble with SS shot small pcs to get a jump on polishing, but in your case(wheels) tumbling isn't an option, at least the soda blast will clean up the pores of the aluminum, making your polishing job easier
Re: Soda blasting ? will it polish aged aluminum wheels? [Re: NV69B7RR] #1143420
12/24/11 05:17 PM
12/24/11 05:17 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
This is what you need, I could do all four in 15 minutes and they would almost look like chrome. They don't need any pretreatment, just a good scrub. Then some Autosol and a wool buffing pad.
Re: Soda blasting ? will it polish aged aluminum wheels? [Re: Challenger 1] #1143421
12/24/11 08:53 PM
12/24/11 08:53 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Thanks for the replies. I'll give that autosol a try. Would simichrome work as well?
Re: Soda blasting ? will it polish aged aluminum wheels? [Re: NV69B7RR] #1143422
12/24/11 08:58 PM
12/24/11 08:58 PM
Cincinnati, Ohio
Cincinnati, Ohio
Not nearly as well...
Re: Soda blasting ? will it polish aged aluminum wheels? [Re: NV69B7RR] #1143423
12/26/11 12:47 PM
12/26/11 12:47 PM
NY
B1duster Offline
B1duster  Offline
NY
wet sand them first, then polish
