Duster Hood Scoop #1142890
12/24/11 01:07 AM
12/24/11 01:07 AM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Motor is finally done and now it is time to get some kind of scoop on the car. With the old TR setup I had a bug catcher with a 2" spacer to get it into the good air. Now I have a single dominator on a 440-3 so the top of the carb nearly sets level with the hood.
I plan to mph somewhere in the low 130's so I am thinking of using a cowl but I have some questions.
1) How close to the windshield does it have to be to become functional?
2) Has anyone got a cowl close to the windshield on Duster using a regular hinged hood?
3) How high off the carb does the scoop need to be with a cowl?
If I go forward facing scoop what could I use that would be functional? I read through several posts and there is two facts that seem to contradict each other in regards to forward facing scoops- a) at speeds over 120 the scoop lifts hard on the hood b) because the scoop is below the "good air" line (front of hood to the top of windsheild) it provides no performance gains. It seems that if the scoop is creating that much lift then it is getting a lot of air.
My third option is to make another bug catcher to go on top of the dominator. Again it would be difficult to get it high enough to get into the "good air".
Sorry so long but thanks for any help.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Duster Hood Scoop [Re: clovis] #1142891
12/24/11 01:18 AM
12/24/11 01:18 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ll patiently watch this topic AGAIN as I`m in the same boat..........5" 6-pack scoop sealed to the hood and have mixed emotions about what scoops actually do work.
Re: Duster Hood Scoop [Re: Thumperdart] #1142892
12/24/11 01:29 AM
12/24/11 01:29 AM
Muskegon Mi
dcr Offline
dcr  Offline
Muskegon Mi
I am currently running a hemi scoop on my duster at 130 mph it does lift a fair amount but does not look like its going to rip off I do plan on running some aluminum under frt of opening in hopes of keeping it flat when I seal it to carb.A buddy of mine ran a prostock style scoop on his dart and went to a hemi scoop and it slowed and went to a cowl hood and regained some of it but he also chaned some other things but he always said the prostock scoop was the fastest.Ill be watching this also.
Re: Duster Hood Scoop [Re: dcr] #1142893
12/24/11 02:15 AM
12/24/11 02:15 AM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
In back to back passes my old 6 pack hood was .1 faster than the cowl hood in this pic. I am running an ootb Indy 440-3.
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: Duster Hood Scoop [Re: Dap] #1142894
12/24/11 02:31 AM
12/24/11 02:31 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Was the 6-pack sealed?
Re: Duster Hood Scoop [Re: Dap] #1142895
12/24/11 02:45 AM
12/24/11 02:45 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
MPH wise, i equaled my best MPH with the old 6pak scoop with my new cowl scoop on the first day! admittedly i changed the grill assy as well but the engine was unchanged between tests. something to be said about the Aerodynamics of the cowl.
before...
after...
Re: Duster Hood Scoop [Re: rebel] #1142896
12/24/11 02:48 AM
12/24/11 02:48 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Is YOUR scoop sealed?
Re: Duster Hood Scoop [Re: Thumperdart] #1142897
12/24/11 02:52 AM
12/24/11 02:52 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
close but not 100% tight as the front clip flexes at speed.
Re: Duster Hood Scoop [Re: Thumperdart] #1142898
12/24/11 03:58 AM
12/24/11 03:58 AM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
Dom, No the 6-pack hood was not sealed. The cowl hood was not sealed either. The only reason I picked up the cowl hood was because my air filter did not fit the 6 -pack scoop.
PRH446
Re: Duster Hood Scoop [Re: Dap] #1142899
12/24/11 10:59 AM
12/24/11 10:59 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Cowl Hood here 6"
Re: Duster Hood Scoop [Re: joshking440] #1142900
12/24/11 11:26 AM
12/24/11 11:26 AM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Dap
What you have is more in line with what I am considering-how tall is it? How far back does it extend past the back of the hood? I see this as the biggest problem with a cowl on a Duster as there is nearly 8" between the back of the hood and windshield.
It seems like the folks that are seeing good results have them close to the windshield, but I am unsure if they seal them or not. I am also still curious if there is some science to how far above the carbs the scoop is.
Just so we keep this interesting, I have considered taking a short cowl scoop and turning it around so the the opening is very near the front of the hood, as to get the "good air", kinda like the aero style super stock scoops that get the opening low and very near the front of the car.
'75 Plymouth Duster
Re: Duster Hood Scoop [Re: clovis] #1142901
12/24/11 12:15 PM
12/24/11 12:15 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
this works great
Re: Duster Hood Scoop [Re: Dap] #1142902
12/24/11 12:48 PM
12/24/11 12:48 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I only have a 3" k&n for that reason............not enuff room for a taller filter cos of the spacer/adapter.
Re: Duster Hood Scoop [Re: joshking440] #1142903
12/24/11 01:08 PM
12/24/11 01:08 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Cowl Hood here 6"
Josh, is yours lift off or bolt on? Love how it looks and would like one for mine that extends that far back, but not sure if I need it to be a lift off or a bolt on...I think a lift off on a street car could be a bit of a pain
Re: Duster Hood Scoop [Re: clovis] #1142904
12/26/11 04:14 AM
12/26/11 04:14 AM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
The cowl scoop is 4" tall and it is probably about 8" from the windshield. My 4.5" K&N air filter fits good underneith it. I am thinking about glassing in the underside of the scoop and sealing off the back leaving the very front part over the rad support grill section open. Then making an air pan to seal the carb to that. The contour of the inside of the hood reminds me of the aero scoop I have.
PRH446
Re: Duster Hood Scoop [Re: Dap] #1142905
12/26/11 12:14 PM
12/26/11 12:14 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Since I am adding the scoop to a metal hood I was going to seal the carb to the hood with the idea that the air would be pulled from the back. This is part of my debate on the length, as I was curious if I need to have the scoop (front edge) very close to the carb thus making the carb the end of tunnel, if that makes any sense. It also plays into the height as I am unsure if the smaller the area the better the potential velocity.
Because of my hinged metal hood, I'm also processing how to the get the scoop to the windshield, currently I am thinking of trying to simply attach a fixed extension on the cowl area that would seal to the scoop when the hood is down.
'75 Plymouth Duster
Re: Duster Hood Scoop [Re: clovis] #1142906
12/26/11 12:35 PM
12/26/11 12:35 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
I think you may want to look at Street Roadster scoops. I believe they would look good on a duster. you could tie it in pretty well to the flat hood and most have a closed back. Check out the cad drawing below.
Re: Duster Hood Scoop [Re: clovis] #1142907
12/26/11 02:46 PM
12/26/11 02:46 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I have a 5" Pro Stock style scoop.The fastest I've gone is 117 and the hood lifts up against 6 hood pins.The scoop is sealed,and I have blocked the scoop opening,(using the cover in the picture) to see if the scoop works and I slowed down a bunch doing so.Now I also use a single 4bbl carb,and according to the Mopar race manuals this scoop shouldn't work,but it works fine for me.
Nautilus Racing-
Re: Duster Hood Scoop [Re: Adrielp] #1142908
12/26/11 02:59 PM
12/26/11 02:59 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Re: Duster Hood Scoop [Re: Plymouth340] #1142909
01/27/12 08:23 AM
01/27/12 08:23 AM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
this works great
Plymouth340 what brand and model scoop is yours?
'75 Plymouth Duster
