Page 1 of 3 1 2 3
What size Big Block #1142802
12/24/11 12:16 AM
12/24/11 12:16 AM
Hilltown Pa
1967dartgt Offline OP
Hilltown Pa
What can you build with a stock 400 block and 4.15 crank? What is the max size you can build?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: What size Big Block [Re: 1967dartgt] #1142803
12/24/11 12:21 AM
12/24/11 12:21 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Why bore any larger than necessary? The popular bore size is 4.375 for 499 cubes. Or 4.25 stroke with 2.2 journal for 511 cubes.
Re: What size Big Block [Re: viperblue72] #1142804
12/24/11 12:24 AM
12/24/11 12:24 AM
Hilltown Pa
Hilltown Pa
Big bores make more power...
Re: What size Big Block [Re: 1967dartgt] #1142805
12/24/11 12:32 AM
12/24/11 12:32 AM
tn
robnbird Offline
robnbird  Offline
tn
figure for yourself. .7854xborexborexstrokex8= however 4.375 bore and 4.150 is enough to stay safe.
Re: What size Big Block [Re: 1967dartgt] #1142806
12/24/11 01:58 AM
12/24/11 01:58 AM
Cab_Burge Online work
Cab_Burge  Online Work
I take it your talking about a BB tall deck 4.15 stroke crank and not a low deck, if so whne you send it out to have the mains turned and the counterweights cut down have them offset grind the rods to either 4.25 or 4.300 stroke with BB chevy rod journla sizes (2.100) You won't have to grind as much in the block to clear the H beam BB Chevy rods like you will with the stock Mopar size rods, no matter what length I have two 400 blocks, one with a 4.300 stroke and the other one is 4.25 stroke both motors make awesome power and unbeilevable toruqe I've built all kinds of stroker BB and the 4.25 and 4.300 are my favorites in a stock block
Re: What size Big Block [Re: 1967dartgt] #1142807
12/24/11 09:13 AM
12/24/11 09:13 AM
NC
440Jim Offline
440Jim  Offline
NC
I wouldn't limit the stroke to 4.15 if you are trying to maximize cubic inches. The 4.250" stroke cranks with 2.2 rod journals fit better and give more CID. And as CAB said, you can have a 4.3x stroke made and it still fits pretty easy. Going all the way to 4.5" gets tough in a low deck (400) block, but fits the RB (440) block easier.
As for bore size, the most common (for good reason) is 4.375". You could go to 4.380" with little difference. The limiting factor, IMO, is the durability when the cylinder walls get thin. So sonic check the wall thickness and only go as big as needed, not as big as possible.
4.375x4.375x3.14159265/4x8x4.250 = 511.12 CID
4.380x4.380x3.14159265/4x8x4.250 = 512.29 CID
4.380x4.380x3.14159265/4x8x4.300 = 518.32 CID
4.380x4.380x3.14159265/4x8x4.375 = 527.36 CID
Re: What size Big Block [Re: 440Jim] #1142808
12/24/11 10:48 AM
12/24/11 10:48 AM
Hilltown Pa
Hilltown Pa
Thanks I have a buddy building a big block to try and run down my small block. I know he has a 400 block and was just at his engine builder and saw his 4.15 crank and just wondered how big of size it could be.
Re: What size Big Block [Re: 1967dartgt] #1142809
12/24/11 11:34 AM
12/24/11 11:34 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
hey Brad i know where theres a set of brand new heads the good victor ones,if he doesnt already have heads.
Re: What size Big Block [Re: 1967dartgt] #1142810
12/24/11 12:10 PM
12/24/11 12:10 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Thanks I have a buddy building a big block to try and run down my small block. I know he has a 400 block and was just at his engine builder and say his 4.15 crank and just wondered how big of size it could be.
should be to hard...lol Most guys run the 471-472ish kit. They seem to run real good. Buddy ran mid 9's in an all steel 3300lb+ duster before going to the 500inch low deck, he was in the 9.20's this year. Not bad for an old foot brake car.
Coming soon!!!!
Re: What size Big Block [Re: 1967dartgt] #1142811
12/24/11 03:43 PM
12/24/11 03:43 PM
V
viperblue72 Offline
viperblue72  Offline
V
Not when its a tradeoff for cylinder rigidity. Not to mention less overheating trouble.
Re: What size Big Block [Re: 1967dartgt] #1142812
12/24/11 04:06 PM
12/24/11 04:06 PM
NC
440Jim Offline
440Jim  Offline
NC
The typical 4.15 stroke sizes:
4.375x4.375x3.14159265/4x8x4.150 = 499.1 CID
4.380x4.380x3.14159265/4x8x4.150 = 500.2 CID
And in a 440 block you see 4.320+0.030" bore = 4.350"
4.350x4.350x3.14159265/4x8x4.150 = 493.4 CID
Re: What size Big Block [Re: fishy340] #1142813
12/24/11 10:34 PM
12/24/11 10:34 PM
Hilltown Pa
Hilltown Pa
No he's got a set of Indy sr's.
Re: What size Big Block [Re: viperblue72] #1142814
12/24/11 10:44 PM
12/24/11 10:44 PM
Hilltown Pa
Hilltown Pa
He says it ran 146 mph last year in the quarter.It was a 499 10 to 1 compression 700+ lift but less then 800 with the indy sr non max wedge in a 3300 lb dart. I think he was streching the truth some what do you guys think. Isn't that like 750hp to run that fast ib that car? From some of the post about big block it doesn't seem like thats what you guy get out of them.
Re: What size Big Block [Re: Mr.Yuck] #1142815
12/24/11 10:47 PM
12/24/11 10:47 PM
Hilltown Pa
Hilltown Pa
Its funny I never see these big blocks run those numbers at the track. Well at least a street car that is, I do see gutted out ones run some mid nines.
Re: What size Big Block [Re: 1967dartgt] #1142816
12/24/11 11:34 PM
12/24/11 11:34 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
It might need some nos, naz, laughing gas, HP helper, spray, NITROUS.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: What size Big Block [Re: pittsburghracer] #1142817
12/25/11 01:09 AM
12/25/11 01:09 AM
Hilltown Pa
Hilltown Pa
Yea I agree those big blocks need the naz to run a number.
Re: What size Big Block [Re: 1967dartgt] #1142818
12/26/11 03:55 PM
12/26/11 03:55 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
They only S/B's I see come close to that are using 2 stages of juice...lol His car runs good, but it's not a street car. It has 2 glass seats and no back seat. He's also or was close to 280. It's tubbed and has big stickies out back, not sure of the size. He broke a rod last race of the season so he's going bigger next year 540 I think. Everything the same except more cubes. Not sure but I think he's running like a 690something solid roller.
Re: What size Big Block [Re: Mr.Yuck] #1142819
12/27/11 11:22 PM
12/27/11 11:22 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
Mr.Yuck if you are talking about Bill's blue demon it is a 499 with a 670 lift roller.He bought the motor out of my brothers full interior 30x10 tire 69 dart with mufflers and went 9.30's at 146.And 1967dart gt if you never see a street car with a big block run good you need to get out to different tracks more often.Not saying they are everywhere but there are some good running ones out there floating around.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: What size Big Block [Re: 1967dartgt] #1142820
12/28/11 12:26 AM
12/28/11 12:26 AM
south central,Pa
mopar_to_ya Offline
mopar_to_ya  Offline
south central,Pa
Maybe if you build it, it would need a power adder, or a big block chevy! From what I understand, you got a 400 plus cu in, w-9 motor going on av 10.0's in an abody at a sea-level track.
And as bdazz smblk(aka; my Brother) says. You might wanna get out more often yo some diff tracks. And btw, that motor isn't anything special at all!!!!
have a nice day
Re: What size Big Block [Re: mopar_to_ya] #1142821
12/28/11 12:54 AM
12/28/11 12:54 AM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
dear mr small block. stock crank 440 with old small indy heads that flow less than some small block indy heads. 262/265cam 630lift solid low 10s. with out having to buy special for these heads parts.
Page 1 of 3 1 2 3
