What size Big Block
#1142802
12/24/11 12:16 AM
12/24/11 12:16 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
What can you build with a stock 400 block and 4.15 crank? What is the max size you can build?
Brett Miller W9 cnc'd heads STR Chassis fabraction
Re: What size Big Block
[Re: viperblue72]
#1142804
12/24/11 12:24 AM
12/24/11 12:24 AM
1967dartgt
Hilltown Pa
Big bores make more power...
[Re: 440Jim]
#1142808
12/24/11 10:48 AM
12/24/11 10:48 AM
1967dartgt
Hilltown Pa
Thanks I have a buddy building a big block to try and run down my small block. I know he has a 400 block and was just at his engine builder and saw his 4.15 crank and just wondered how big of size it could be.
[Re: 1967dartgt]
#1142810
12/24/11 12:10 PM
12/24/11 12:10 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Thanks I have a buddy building a big block to try and run down my small block. I know he has a 400 block and was just at his engine builder and say his 4.15 crank and just wondered how big of size it could be.
should be to hard...lol Most guys run the 471-472ish kit. They seem to run real good. Buddy ran mid 9's in an all steel 3300lb+ duster before going to the 500inch low deck, he was in the 9.20's this year. Not bad for an old foot brake car.
[Re: 1967dartgt]
#1142812
12/24/11 04:06 PM
12/24/11 04:06 PM
Posts: 16,923 NC
440Jim
NC
The typical 4.15 stroke sizes:
4.375x4.375x3.14159265/4x8x4.150 = 499.1 CID 4.380x4.380x3.14159265/4x8x4.150 = 500.2 CID
And in a 440 block you see 4.320+0.030" bore = 4.350" 4.350x4.350x3.14159265/4x8x4.150 = 493.4 CID
[Re: viperblue72]
#1142814
12/24/11 10:44 PM
12/24/11 10:44 PM
1967dartgt
Hilltown Pa
He says it ran 146 mph last year in the quarter.It was a 499 10 to 1 compression 700+ lift but less then 800 with the indy sr non max wedge in a 3300 lb dart. I think he was streching the truth some what do you guys think. Isn't that like 750hp to run that fast ib that car? From some of the post about big block it doesn't seem like thats what you guy get out of them.
[Re: Mr.Yuck]
#1142815
12/24/11 10:47 PM
12/24/11 10:47 PM
1967dartgt
Hilltown Pa
Its funny I never see these big blocks run those numbers at the track. Well at least a street car that is, I do see gutted out ones run some mid nines.
[Re: 1967dartgt]
#1142818
12/26/11 03:55 PM
12/26/11 03:55 PM
Mr.Yuck
Brookeville, Md
They only S/B's I see come close to that are using 2 stages of juice...lol His car runs good, but it's not a street car. It has 2 glass seats and no back seat. He's also or was close to 280. It's tubbed and has big stickies out back, not sure of the size. He broke a rod last race of the season so he's going bigger next year 540 I think. Everything the same except more cubes. Not sure but I think he's running like a 690something solid roller.
[Re: Mr.Yuck]
#1142819
12/27/11 11:22 PM
12/27/11 11:22 PM
Posts: 437 south central pa
bdaz smblk
south central pa
Mr.Yuck if you are talking about Bill's blue demon it is a 499 with a 670 lift roller.He bought the motor out of my brothers full interior 30x10 tire 69 dart with mufflers and went 9.30's at 146.And 1967dart gt if you never see a street car with a big block run good you need to get out to different tracks more often.Not saying they are everywhere but there are some good running ones out there floating around.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
[Re: 1967dartgt]
#1142820
12/28/11 12:26 AM
12/28/11 12:26 AM
Posts: 1,327 south central,Pa
mopar_to_ya
south central,Pa
Yea I agree those big blocks need the naz to run a number
Maybe if you build it, it would need a power adder, or a big block chevy! From what I understand, you got a 400 plus cu in, w-9 motor going on av 10.0's in an abody at a sea-level track. And as bdazz smblk(aka; my Brother) says. You might wanna get out more often yo some diff tracks. And btw, that motor isn't anything special at all!!!!
have a nice day
