Yes i was able to run the 275/60/15 out back but i needed to trim about 1/2 inch of the Inner wheel lip. Plus i used a 15 x 7 steel rim with a 4.5 inch offset i had to let out the air & work them in but they fit and the back off the tire near the spring has just at a 1 inch spacing & the front of the wheel opening there is just over 1 1/4 inch of space.
The fronts i ran 245/60/15 on steel rims. the car handles way better than it did before.
Thanks for all your replies was helpful.
you can get a 275/60/15 out back and I'd run a 215/75/15 or 225/70/15 up front.
