stage 6 alum. heads #1142471
12/23/11 02:15 PM
12/23/11 02:15 PM
Florida, USA
MoparMichael Offline OP
Florida, USA
anybody run these ? bigblock. how much porting do these heads need ? can you get 330 c.f.m. and who does the best porting for mopar heads ? thanks and merry x-mas to all
Re: stage 6 alum. heads [Re: MoparMichael] #1142472
12/23/11 02:20 PM
12/23/11 02:20 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I have a set of ported Stage VI's on my 440-6. No idea on what they flow, or if they will flow 330. Only thing I don't like is the rocker assembly hangs over the top of the head making vavle covers a PITA. I had to get reverse lip covers and grind 1/2 of the upper lip off to clear the H/S rockers. I'm going to guess there are better choices out there for the money. Most "mopar" products are overpriced. Now if you can get a used set, it's a different story.
Coming soon!!!!
Re: stage 6 alum. heads [Re: Mr.Yuck] #1142473
12/23/11 02:31 PM
12/23/11 02:31 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
I have a set of ported Stage VI's on my 440-6. No idea on what they flow, or if they will flow 330. Only thing I don't like is the rocker assembly hangs over the top of the head making valve covers a PITA. I had to get reverse lip covers and grind 1/2 of the upper lip off to clear the H/S rockers. I'm going to guess there are better choices out there for the money. Most "mopar" products are overpriced. Now if you can get a used set, it's a different story.
That's the rocker, I used Erson rockers, look like the sharps with a set of cast alum. valvecovers.
They need a lot of work to get to 330 from how they are delivered.
Contact fast68plymouth he has a lot of experience with them.
Re: stage 6 alum. heads [Re: MoparMichael] #1142474
12/23/11 02:34 PM
12/23/11 02:34 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
anybody run these ?
I used to w/ good results. Only sold mine earlier this year after deciding maybe I could go faster w/ ported Victor heads (not proven yet...)
Quite a bit, since out of the box they're really not "ready to run". That includes setting the guide clearance, doing a good valve job, etc.
That's more than I think 95% of the ported Stage VIs (not counting Chapman's CNC'd castings) have ever seen. Figure more like 310+ w/ standard 2.14" valves. There's an archived thread under the OLD Moparts tech articles (linked from front page, not from forum index) that covers some of this stuff from years ago.
Well, I know who did mine and he's the same person I'd send a set to if I was doing them again: Porter Racing Heads, S. Burlington, VT
