front end clunk revisited
#1142271
12/23/11 08:35 AM
12/23/11 08:35 AM
Posts: 1,012 indiana
mcmopars
indiana
dont clunk going over bumps,front end is very tight and responsive.it only clunks in the right front tire area whne your stopped and turning left.and will only clunk loud once.front end cant have 5k miles on it.firm feel arms feel nice and tight.no movement with pry bar under tire with lca loaded.shocks feel tight,i say feel as with grabbing and trying to move.driver side lca bushing has some tearing,it should be replaced but i think the noise would be comming fromdrivers side.trow some guys at me guys.wheel bearings are new
Re: front end clunk revisited
[Re: mcmopars]
#1142272
12/23/11 11:30 AM
12/23/11 11:30 AM
RapidRobert
I remember your thread. I'd check the center link/idler/pitman arms/ball joints for binding as a helper turns it right w you underneath
[Re: Jim_Lusk]
#1142276
12/23/11 06:18 PM
12/23/11 06:18 PM
mcmopars
indiana
thanks for they help,here is what it is not,ball joints all tight no movement whatever.links were replaced with new pollys,wheel bearings,idler are is nice and tight,tie rods are also tight.it only clunks when im stopped,taking off into a left turn,that is when it will clunk loud,and only once through the turn,in the right wheel area.it wont do it on jack stands.it has to be with weight on the defective part.i cant get any movement grabbing the shock either.jim please what do you mean?im not really sure what you mean.but im at my end as to solving this issue.uca bushings seem good,holds a good alignment.1973 duster.steering box bolts are tight and is a firm feel unit
[Re: mcmopars]
#1142281
12/24/11 12:26 AM
12/24/11 12:26 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
The front end doesn't clunk going over bumps, front end is very tight and responsive. It only clunks in the right front tire area when your stopped and turning left, and will only clunk loud once. Front end can't have 5k miles on it. Firm Feel arms feel nice and tight. No movement with pry bar under tire with lca loaded. Shocks feel tight. Driver side lca bushing has some tearing, it should be replaced but I think the noise would be coming from drivers side.
Maybe the right upper ball joint is defective?
