An electric supercharger????? #1142125
12/22/11 11:37 PM
12/22/11 11:37 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Has anyone heard of that before ??
Check this and tell me what you think....
5 lbs of boost 179.99 $
Dan
http://www.superchargertuning.com/Plymouth/Barracuda/
Re: An electric supercharger????? [Re: Wedgeman] #1142126
12/22/11 11:48 PM
12/22/11 11:48 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Absolutly not even close to an option......remember to build boost you have to beable to OVERFILL the cylinder with air.....that little fan wouldnt overfill N20MSTRs blow up doll...
Re: An electric supercharger????? [Re: joshking440] #1142127
12/22/11 11:50 PM
12/22/11 11:50 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
My thought too....may be not enough cfm to buid boost
Re: An electric supercharger????? [Re: joshking440] #1142128
12/22/11 11:53 PM
12/22/11 11:53 PM
Renton Washington
Triple Threat Offline
Renton Washington
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: An electric supercharger????? [Re: Wedgeman] #1142129
12/23/11 12:12 AM
12/23/11 12:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Think of it this way.... how much HP does it take to
compress the air to make 5 psi... its gonna take
ALOT more than a 15 amp motor
Re: An electric supercharger????? [Re: Triple Threat] #1142130
12/23/11 12:14 AM
12/23/11 12:14 AM
Az
Crizila Offline
Crizila  Offline
Az
I could see it as a cooling fan when you are stuck in staging on a 95 degree day. A little pricey for that I guess.
Fastest 300
Re: An electric supercharger????? [Re: Crizila] #1142131
12/23/11 12:21 AM
12/23/11 12:21 AM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
did anyone read the text? a little history i did not know....
Re: An electric supercharger????? [Re: Wedgeman] #1142132
12/23/11 12:23 AM
12/23/11 12:23 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
i made a drawing for a fluid drive off the power steering with a much more agressive fan.
Re: An electric supercharger????? [Re: j.mcconnell] #1142133
12/23/11 12:29 AM
12/23/11 12:29 AM
Az
Crizila Offline
Crizila  Offline
Az
Yes, quite interesting.
Fastest 300
Re: An electric supercharger????? [Re: Wedgeman] #1142134
12/23/11 02:42 AM
12/23/11 02:42 AM
New York
polyspheric Offline
polyspheric  Offline
New York
It's a boat bilge pump with some bling. Used to sell on eBay for $29.95, and they got banned.
No, it doesn't work.
There are electric superchargers that work - they have huge motors and need 200 lbs. worth of batteries.
Boffin Emeritus
Re: An electric supercharger????? [Re: polyspheric] #1142135
12/23/11 10:06 AM
12/23/11 10:06 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i wonder if it works better that the TORNADO.
Re: An electric supercharger????? [Re: Wedgeman] #1142136
12/23/11 10:55 AM
12/23/11 10:55 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
those are a scam item for the 4 banger crowd.
Coming soon!!!!
Re: An electric supercharger????? [Re: Mr.Yuck] #1142137
12/23/11 11:14 AM
12/23/11 11:14 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
stop lying guys, Josh has 4 of them under his hood
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: An electric supercharger????? [Re: bigtimeauto] #1142138
12/23/11 11:32 AM
12/23/11 11:32 AM
moparx Offline
moparx  Offline
if it includes stickers, then it GOTTA be worth at LEAST 400hp.
Re: An electric supercharger????? [Re: joshking440] #1142139
12/23/11 12:18 PM
12/23/11 12:18 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Now thats some funny chit
I think if you hookd myb 3 or 4 of them up in series it might work
Re: An electric supercharger????? [Re: 340RICK] #1142140
12/23/11 12:19 PM
12/23/11 12:19 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Re: An electric supercharger????? [Re: Wedgeman] #1142141
12/23/11 12:36 PM
12/23/11 12:36 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
We tried one and it worked awesome!......
On a 24hp Briggs & Stratton in a golf cart. We put a micro-switchon the throttle linkage - to a relay - to the blower. Well it DID work awesome until we hit too large of a bump and something happened to break the impellers and the engine ingested it at WOT. The throttle was hung open (woo hoo!!! Prolly 30 hp of unbridled fury!!!) and the plastic blades got melted onto the exhaust valve and it had no compression. Bummer!! We were having fun riding wheelies with two of us in the golf cart.
It DID make a huge difference on that little tiny engine - while it lasted. Too bad we broke it so far from camp.
On my Mopar? I doubt it would even notice.
Re: An electric supercharger????? [Re: Duner] #1142142
12/23/11 12:49 PM
12/23/11 12:49 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
to move enough air for a big V8 engine, you'd have to have what...a 20? 25? hp electric motor? how much HP does a belt driven supercharger consume?
Whatever that number is, you'd need an electric motor of the same rating. then you'd need the electric source to feed it. don't try running it off your alternator, cause A) you'll fry it, and B) you're just adding that Hp drain right back to the crank, and you might as well use a belt driven or exhaust driven blower.
batteries? like said, 200 or more pounds of lead/acid to create the juice needed to run an electric motor that big. is the 100-ish hp gain from a blower enough to overcome all the added weight of the blower, plumbing, wiring, and batteries?
now, adding that little blower to a golf cart or brigs go-cart, sounds like a TON of fun!
**Photobucket sucks**
Re: An electric supercharger????? [Re: domingo] #1142143
12/23/11 01:27 PM
12/23/11 01:27 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
how about one of those and a double stack of tordado,s
Re: An electric supercharger????? [Re: bonefish] #1142144
12/23/11 01:38 PM
12/23/11 01:38 PM
Kirkland, Washington
Pacnorthcuda Offline
"Buy Plymouth Barracuda Electric Supercharger Bolt-On Kit
This supercharger is a two door car that was manufactured by the Plymouth division of Chrysler Corporation from 1964 through to 1974.The first generation Barracuda supercharging fastback A-body coupe based on the Plymouth Valiant had distinctive wraparound back glass and was available up to 1966 from 1964. The second Barracuda even though was just like the Valiant it had superchargers and was available in fastback, notchback and convertible versions. The bolt on supercharger 1970-1974E-body Barracuda, no longer had a valiant feature instead it was available as a coupe and a convertible both which were different from the previous makes and models. The electric supercharger E-body Barracuda was available and was able to shake off the stigma of economy car from 1970 to 1974 and three versions were offered into the market; the base Barracuda, the luxury oriented Gran Coupe and the sport model the ‘Cuda. The high performance models were derived from the 1969 option and were marketed as the ‘Cuda. The engine produced 190 horsepower that is equal to 140 kilo watt and produced a speed of admirable quantity not forgetting the torque."
Who the hell writes crap like that???
Is there a parallel mopar universe that nobody told me about???
