Re: 8 3/4 gear noise more noticeable when warmed up
[Re: RTshaker]
#1141896
12/22/11 10:31 PM
12/22/11 10:31 PM
RapidRobert
It was quiet before you changed yokes?
[Re: Unfair Advantage]
#1141902
12/23/11 09:27 PM
12/23/11 09:27 PM
RapidRobert
I would pull it & see what you do have now for backlash & post it & I would not drive it as more miles wears in the improper adjustment (for the worse), aggravating it & might not be able to adj all (or most) of it(the noise) out
#1141904
12/25/11 02:21 PM
12/25/11 02:21 PM
RapidRobert
Yeah I'm not sure if you'd go tighter or looser tho 1st thought was tighter (but not sure). I'm getting ready to do my 1st R&P as how hard can it be as there's only pinion depth (forward/backward) and backlash (in/out). I did add a sure grip to a 7&1/4 and months later it has a ton of backlash (no noise tho) and I merely duplicated the tightest backlash reading I got w the open before I opened it up which was kind of disheartening & dont think I forgot to tighten anything & it had the threaded side wheel locks in place so...
