Page 13 of 14 1 2 11 12 13 14
Re: Subframe connectors, which way should we [Re: mopurist] #1141
09/08/05 07:24 PM
09/08/05 07:24 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Hello, I will send you a privite message so I can send you all the pictures I have. They take a long time to download onto Moparts. And you are right. Pictures of the install made it a lot easier to put my own in. I took a lot of pictures so you should have no problem making up your own.
Re: Subframe connectors, which way should we [Re: rapom] #1142
09/08/05 09:49 PM
09/08/05 09:49 PM
Tomorrow.
Damned67 Offline
Damned67  Offline
Tomorrow.
I read through thhis thread just the other day. Please, someone repost the pics?
Re: Subframe connectors, which way should we [Re: Damned67] #1143
09/09/05 04:08 PM
09/09/05 04:08 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Ok, here you go. Here are the connectors with 3 x 5" 1/8"thick plates welded on the ends.
Re: Subframe connectors, which way should we [Re: rapom] #1144
09/09/05 04:10 PM
09/09/05 04:10 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Here is the floor cut for the connectors. Use the connectors to trace the lines in the floor to cut out.
Re: Subframe connectors, which way should we [Re: rapom] #1145
09/09/05 04:12 PM
09/09/05 04:12 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Here you can see the frame rail cut out so the connectors can slide in.
Re: Subframe connectors, which way should we [Re: rapom] #1146
09/09/05 04:14 PM
09/09/05 04:14 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I drilled some holes in the side of the rear frame rails to plug weld the connectors. May be a little over kill.
Re: Subframe connectors, which way should we [Re: rapom] #1147
09/09/05 04:16 PM
09/09/05 04:16 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Frame connector slides nicely into frame rail like it was made to fit.
Re: Subframe connectors, which way should we [Re: rapom] #1148
09/09/05 04:17 PM
09/09/05 04:17 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Getting ready to weld front of connectors.
Re: Subframe connectors, which way should we [Re: rapom] #1149
09/09/05 04:19 PM
09/09/05 04:19 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Top view.
Re: Subframe connectors, which way should we [Re: rapom] #1150
09/09/05 04:21 PM
09/09/05 04:21 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Welded in connectors
Re: Subframe connectors, which way should we [Re: rapom] #1151
09/09/05 04:23 PM
09/09/05 04:23 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Another view
Re: Subframe connectors, which way should we [Re: rapom] #1152
09/09/05 04:33 PM
09/09/05 04:33 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
And another
Re: Subframe connectors, which way should we [Re: rapom] #1153
09/09/05 04:37 PM
09/09/05 04:37 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
After sandblasting and Zerorusting. Inside frame rails were painted after picture was taken.
Re: Subframe connectors, which way should we [Re: mopurist] #1154
09/09/05 10:22 PM
09/09/05 10:22 PM
Raleigh, NC
John426 Offline
super gas
John426  Offline
super gas
Raleigh, NC
Sorry about the web site - we are behind on all the updates!
I did check out uscartool.com, but I couldn't find any information on connectors for a 69 b-body (only e-bodies and 71-2 b-body).
They do seem nice, and if they are available for a 69, I would definitely give them serious consideration, even though they are nearly 10x the cost of a length of 2x3. The almost-factory look and no need to worry about hacking the floorpan may be worth it.
We do have the 66-70 B-Body versions done along with the E Body versions - just drop a note or send a PM for all the details (pricing!) - I have pictures of several installs done by test pilots.
Biggest benefit of using the laser cut version is not haing to cut the floor. Hard to carpet after you weld the tube in as well (chuckle), but that would be les important for a full-on race car.
Hope That Helps!!
John Pasemann
www.UsCarTool.com
919-855-8200
PS - we have a banner ad coming here on moparts!!
Re: Subframe connectors, which way should we [Re: John426] #1155
11/01/05 03:41 AM
11/01/05 03:41 AM
Clarkston,MI
Todd_DesMarais Offline
super street
super street
Clarkston,MI
Rapom, good to see it still kicking (the post) I thought for sure that the pics you posted were from Zipp's car until I realized I don't own those jack stands
Nice job !! looks great with the zero rust. (please PM me with more info on that product)
Zipp's car (polara) just left tonight after a 3 month visit to repair the drunk driver's reconfigure, so......now the Belvedere gets finished !! Pics to come.
John426, awesome work on those connectors also !! I like the clean factory look, and will be ordering two sets (66 b-body & 74 e-body) in the near future as I can't bring myself to cut my own cars, just others.
Todd
aduC' 47 IIeredevleB 66 383 etilletaS 66 DTC 0053 MAR 50 "ssenlli latnem a dna ,ybboh a neewteb enil enif a si ereht"
Re: Subframe connectors, which way should we [Re: ZIPPY] #1156
09/03/06 10:40 AM
09/03/06 10:40 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
bump
Re: Subframe connectors, which way should we [Re: nomore65BelvJim] #1157
09/03/06 12:08 PM
09/03/06 12:08 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
I just bought the U.S.Car Tool 69 b-body frame connectors at the Nats and installing them now.
Warning if your car has been thrashed on in the past these connectors are not an easy fit!
Much grinding work will be needed on the high spots of the connectors to make them fit flush.
Nice people out there to deal with though,and seems like a great quality product.
Re: Subframe connectors, which way should we [Re: jcastle1] #1158
09/03/06 02:58 PM
09/03/06 02:58 PM
Mooresville, NC
A70Runner Offline
A70Runner  Offline
Mooresville, NC
Is this the longest running thread in history? The first post was made Wed Jul 30 2003 02:28 PM WOW. On topic I have the US Car tool connectors and they fit great.
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
Re: Subframe connectors, which way should we [Re: A70Runner] #1159
09/03/06 04:22 PM
09/03/06 04:22 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
Me too, to John... A big
Re: Subframe connectors, which way should we [Re: CRE2004] #1160
09/03/06 06:52 PM
09/03/06 06:52 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Hey this thread came back again
Rich H.
Esse Quam Videri
