anyone else have probems with 440source water necks #1138649
12/18/11 03:20 PM
12/18/11 03:20 PM
fresno
hyefatman Offline OP
fresno
bought 5 a few years back and all leak
Re: anyone else have probems with 440source water necks [Re: hyefatman] #1138650
12/18/11 03:22 PM
12/18/11 03:22 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
really...
Re: anyone else have probems with 440source water necks [Re: Challenger 1] #1138651
12/18/11 03:27 PM
12/18/11 03:27 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
A few years back & your posting about it now??????
Re: anyone else have probems with 440source water necks [Re: hyefatman] #1138652
12/18/11 04:14 PM
12/18/11 04:14 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
could be your "installation procedure" rather the parts, I've had factory and chrome water necks leak,...analyze, remedy, re-install
Re: anyone else have probems with 440source water necks [Re: hyefatman] #1138653
12/18/11 04:27 PM
12/18/11 04:27 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
I've bought 5 in the last 3 years, none leak. All fit and look perfect. Now, if you use the chrome type....good luck! Jeff
Re: anyone else have probems with 440source water necks [Re: hyefatman] #1138654
12/18/11 04:31 PM
12/18/11 04:31 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Why bother with the chrome junk..
NAPA sells a cast iron clone of the Mopar OE original for $8...
Just my $0.02..
Re: anyone else have probems with 440source water necks [Re: Sinitro] #1138655
12/18/11 05:47 PM
12/18/11 05:47 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
The one I got from them a 5 or 6 years ago had the bolt holes spaced wrong, and leaks slightly.
Re: anyone else have probems with 440source water necks [Re: Sinitro] #1138656
12/18/11 05:51 PM
12/18/11 05:51 PM
BDW Offline
BDW  Offline
Just my $0.02..
Save your money
Re: anyone else have probems with 440source water necks [Re: NV69B7RR] #1138657
12/18/11 06:05 PM
12/18/11 06:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: anyone else have probems with 440source water necks [Re: JohnRR] #1138658
12/18/11 06:16 PM
12/18/11 06:16 PM
fresno
fresno
all leak and holes off will go to napa thanks
Re: anyone else have probems with 440source water necks [Re: hyefatman] #1138659
12/18/11 06:19 PM
12/18/11 06:19 PM
fresno
fresno
how about their harmonic balancers - bought couple of them at the same time and now they are starting to wobble --
Re: anyone else have probems with 440source water necks [Re: hyefatman] #1138660
12/18/11 06:45 PM
12/18/11 06:45 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
Ditto on the crap chrome ones. I went with the cheap over the counter auto parts store cast ones and no problems for years. Never tried the billet alum. ones.
Re: anyone else have probems with 440source water necks [Re: hyefatman] #1138661
12/18/11 06:55 PM
12/18/11 06:55 PM
Cincinnati, Ohio
Cincinnati, Ohio
You do get what you pay for...I don't care what it is. Sucks now don't it? I'd get them off of there before they cause more damage. I wonder what your bearings look like?
Re: anyone else have probems with 440source water necks [Re: Challenger 1] #1138662
12/18/11 07:11 PM
12/18/11 07:11 PM
fresno
fresno
well i did not know about the quality of the stuff they sell- live and learn
Re: anyone else have probems with 440source water necks [Re: hyefatman] #1138663
12/18/11 07:29 PM
12/18/11 07:29 PM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
JUNK
Re: anyone else have probems with 440source water necks [Re: TOMRR] #1138664
12/18/11 07:44 PM
12/18/11 07:44 PM
Cincinnati, Ohio
Cincinnati, Ohio
I don't see how the places selling the cheap chinese knock off's are gonna stay in business?
Sure some of the stuff is OK, but what about all the stuff that isn't?
How long until people figure out it's best to spend more the first time and not have to replace it so often?
I don't see how the sellers of the junk can sleep at night. Or maybe they don't know any better until they have ton's of failures and figure it out that way, letting there customers bear the R&D
Re: anyone else have probems with 440source water necks [Re: TOMRR] #1138665
12/18/11 07:45 PM
12/18/11 07:45 PM
I've had all kinds of different thermosat housing leak over the years, stock, after market, high dollar and cheap ones I guess I'm just lucky
Re: anyone else have probems with 440source water necks [Re: hyefatman] #1138666
12/18/11 07:46 PM
12/18/11 07:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Stop leak can fix a leaky thermostat housing but
stop leak aint gonna help a junk damper... get that
thing off there before you have real problems
Re: anyone else have probems with 440source water necks [Re: MR_P_BODY] #1138667
12/18/11 07:56 PM
12/18/11 07:56 PM
IN
ahy Offline
ahy  Offline
IN
The parts store iron necks work great. I believe the high end billet aluminum work well also. Stay away from anything in between, especially chrome!
I check them all for flatness and hit them with the belt sander if needed. Torque bolts gently or they will warp and leak. Use a little sealer for insurance... I like Permatex #1 in this application.
Re: anyone else have probems with 440source water necks [Re: Cab_Burge] #1138668
12/18/11 08:12 PM
12/18/11 08:12 PM
Cincinnati, Ohio
Cincinnati, Ohio
I stopped using gaskets a long time ago and haven't had any leaks since.
