Six-Pac Stroker. Info for Set-Up Needed. Jetting etc:
#113864
09/02/08 03:29 AM
09/02/08 03:29 AM
Posts: 48 New Zealand
Big-Mike
New Zealand
Help Please! I have a 440 stroker(496) It has 10:1 with 193lbs cranking pressure.18inches vacuum @ 800rpm. Comp-Cams 294solid 248@050 Lift 0.560 with 1:6 Rockers.Installed straight-up.Was using Weiand Xcelerator 7512 Single-Plane Manifold.650 D/P Holley. Were using Hughes Engines Heads,Stage 2 452's Factory Iron. Now running Stealth/440 Source which have same pressure & revability. 6800 in 1st & 2nd on 4-Speed New-Process with 2:75 Gears out back. Car wit me weighs 3960lbs & runs 12:00-12:25@117-118mph in the 1/4 mile. I have a Six-Pac set-up with Fuel Technologies Metering Plates. Something is wrong, it does not like to pull much passed 6000rpm. 64 jets centre,10:5 Power-Valve; 84 jets for end carbs. Accelerationion seems considerably less than 650 as well. Any ideas, especially from someone with similar set-up or thoses in the know.
Re: Six-Pac Stroker. Info for Set-Up Needed. Jetting etc:
[Re: Big-Mike]
#113867
09/02/08 08:12 AM
09/02/08 08:12 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I was curious about the horsepower your motor is putting out. My 493 inch sixpack motor has it's horsepower peak down at around 5500 rpm and runs out of cam at just past 6000 rpm, but it sure does run good at and below those numbers.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#113868
09/02/08 09:48 AM
09/02/08 09:48 AM
quick77rt
Parts Problem
Parts Problem
[Re: Big-Mike]
#113870
09/02/08 03:08 PM
09/02/08 03:08 PM
jbc426
West Coast, USA
That sounds pretty healthy. How much does that work out to at the flywheel?
[Re: jbc426]
#113871
09/02/08 03:16 PM
09/02/08 03:16 PM
Hey, another Big Mike
[Re: Big-Mike]
#113876
09/02/08 07:24 PM
09/02/08 07:24 PM
jbc426
West Coast, USA
Beat this! I just put my weight & terminal speed into the Horse-Power calculator in the tech archives, & it says i make 508 HP at the wheels.
Those are some good numbers. With a 17% driveline loss, that comes out to 594 horsepower at the flywheel! I bet it sounds great when your on that chassis dyno. I would give you my jet sizes, but they would probably be a little on the rich side. When they were dynoing my motor, they kept putting bigger and bigger jets in and the horsepower kept going up until it got to that happy spot. Mine doesn't rev up like yours either, and the horsepower begins to drop off after 5500 rpm.
[Re: jbc426]
#113877
09/02/08 07:46 PM
09/02/08 07:46 PM
Posts: 3,682 South San Francisco, Ca
70sixpkrt
With those kind of numbers you should be dipping into the 11s.
[Re: jbc426]
#113879
09/02/08 11:21 PM
09/02/08 11:21 PM
Big-Mike
New Zealand
Thanks for the chat guys. I only occassionally wind it into the 6800 area if I wanna screw up Boy-Racers (Brains) in their Jappa's by takin the odd one for a ride. At the drags, i am some-what into 3rd gear,maybe half-way. It would be well in the 11's, but this is a car i can just loaf around in,&,once moving at 10mph will blow the socks off most comers. Quite happy with tall gears, afterall, low gearing only has the punch in that first instant. In low, with full tank of juice & 60ft of 5/8th chain in the boot,& the 850 on, she'll srew sideways every time even if i accelerate smoothly & then at say 50-60mph push that lasy third of throttle. Tires are 255x45x17 ZR-Sumitomo's.
[Re: jbc426]
#113881
09/02/08 11:47 PM
09/02/08 11:47 PM
Posts: 1,374 Houston,Tx.
Lee446
Houston,Tx.
If your running 12.0's with a 2.76 rear, you have nothing to complain about! Why rev the engine over 6K if it does not do anything for performance? With a single 4 setup, a Holley HP 950 has made huge differences over 750 and 850's with the strokers I have been involved with! IMO, you picked a pretty good all round cam for a street car, I have never seen one with that much vac at idle, wish mine did. From all accounts, the Stealth heads run pretty close out of the box to the Eddy heads, and they dont flow enough for your combo to make max hp and probably why it does not make any more power over 6k. If you shifted around 5800 you would probably run better times at the track. Here is my combo for an all around street car. 493 stroker, 10.54-1 comp. Comp custom solid from Dwayne Porter, Porter racing heads. Specs off top of my head, 254/258@50, .582/.597 on 108*. Out of the box Eddy's with Isky 8005a springs. Hooker S/C 2" headers with 3" full(quiet) exhaust. Torqueflite trans with Dynamic tight 10" 3600 stall converter. Factory 6 pack, cold intake, staggered jetting on ends with QFT jet plates 78/84, center carb 65 mains, I believe I drilled the accel pump nozzles to .035 and used the red accel pump cam in the #2 position, stock 30 cc. pump. My vac in gear at idle was around 7" and I ran a 3.5 power valve. I am also at sea level. 69 RR with a/c and a 6 point bar, 4120 lbs w/driver.Dana 60 w/3.54 gears Best run through mufflers on 30" tall slicks, 11.48@117, average times through the muffs on Goodyear Eagle GT 2 street tires, 11.78@115, 60 ft. in the 1.80 range, but on a well prepped track, 1.74 was common. Best et's were found to be with a shift point of 5800 rpm. My cam was a little big, but when Dwayne spec'd it out, I was planning on having the heads ported which I have since done. Unfortunately, I had a garage fire that burned up both of my Mopars and the whole shop before I had a chance to run the new heads. I won't know until next spring how everything will do when I put the new car togeather, but I think it is safe to say you could benefit greatly from some proffesional porting on your heads. Also be sure you have a good fuel pump so you don't run out of fuel on the big end. With your mph, no doubt you have all the potential for low to mid 11's in street trim, a bit more gear would sure help. Hope this helps!
