Re: SAWMILL HEMI
[Re: 19swinger70]
#1138233
12/20/11 09:40 AM
12/20/11 09:40 AM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
Mike,
You were correct in saying that the dimpled valve covers do not indicate an adjustable valvetrain. I learn something new everyday!
I removed a V-cover and see a fairly clean situation. No layers of thick sludge or any broken components. The hour meter on the sawmill rig shows 1237 hrs.
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
Re: SAWMILL HEMI
[Re: 19swinger70]
#1138234
12/20/11 12:06 PM
12/20/11 12:06 PM
Posts: 1,513 AZ
Mike P
AZ
Bummer, I was really hoping you would end up with adjustables. I'm using adjustable pushrods on both of my first gen Hemi's. The one only has a few hours on the test stand, but the 354 in my 57 Plymouth has been going with them for 5 years and 15,000 miles on them with no problems. If you decide to rebuild your 354 just a word of caution about the Hot Hemi heads HV oil pump. I have heard that there may be some problems with them. http://www.hotrodders.com/forum/hot-heads-oil-pump-failures-203640.html Don't get me wrong, I've had good luck with the parts I have bought form Bob at hot heads, but that post was kind of worrysome (I'm running stock replacement pumps in mine so it's not an issue for me). I'd also recommend Tex Smiths Hemi book if you don't already have a copy.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
Re: SAWMILL HEMI
[Re: Mike P]
#1138235
12/20/11 02:09 PM
12/20/11 02:09 PM
19swinger70
Richmond, Indiana
I recently purchased the Tex book. it is a good one. I will keep the Hot Heads thing in mind.
Re: SAWMILL HEMI
[Re: 56_Royal_Lancer]
#1138239
12/21/11 06:22 PM
12/21/11 06:22 PM
19swinger70
Richmond, Indiana
I am not sure about the 315 - it isnt hurting me to keep it around for a potential future project. Or, I might use it as trading bait at some point. It is nice that it is complete from carb to pan, unmolested, and I know a little bit of its history. I might still try to locate some Hemi heads for it.
In the end, I couldnt pass up the 354!
Re: SAWMILL HEMI
[Re: 19swinger70]
#1138241
12/22/11 08:01 PM
12/22/11 08:01 PM
Posts: 7,496 Minnesota
Hemi_Joel
Minnesota
That had to be one awesome sounding sawmill with a straight pipe Hemi!
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
