OEM HD Springs vs. AFCO XHD Springs - '72 B #1137507
12/17/11 01:30 AM
12/17/11 01:30 AM
MassHole Central
rtman Offline OP
rtman  Offline OP
MassHole Central
Just put AFCO XHD springs on now, car sits high in rear (too high to my eye). Will MP OEM HD springs lower the rear end?
Re: OEM HD Springs vs. AFCO XHD Springs - '72 B [Re: rtman] #1137508
12/17/11 01:34 AM
12/17/11 01:34 AM
MassHole Central
rtman Offline OP
rtman  Offline OP
MassHole Central
Dayclona?
Re: OEM HD Springs vs. AFCO XHD Springs - '72 B [Re: rtman] #1137509
12/17/11 01:43 AM
12/17/11 01:43 AM
Upstate, NY
sixpack4spd Offline
sixpack4spd  Offline
Upstate, NY
Yuck, and I thought mine sat too high. Did you tighten everything up with the car in the air? You should put it together with the bolts loose (on the springs and shackles) and don't tighten them up until the car is on the ground. Sometimes the rubber bushings will bind and make the car sit higher than it should. Have you driven the car with the springs on it?
Re: OEM HD Springs vs. AFCO XHD Springs - '72 B [Re: sixpack4spd] #1137510
12/17/11 01:58 AM
12/17/11 01:58 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Just what I was going to post ....I had the same issue upon XHD installs, too high, but do as listed above and take it out for some driving time it will settle down, might take a few miles of suspenion rebounding to settle them out, the XHD in my Charger came down about 1 1/2" after a week or so
Mike
Re: OEM HD Springs vs. AFCO XHD Springs - '72 B [Re: rtman] #1137511
12/17/11 02:07 AM
12/17/11 02:07 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Like the others say...tighten everything up while
its at curb height... also the thing with HD springs
is, it seems like all they do is put more arch in them
instead of making them with a higher pounds per inch
of travel
Re: OEM HD Springs vs. AFCO XHD Springs - '72 B [Re: rtman] #1137512
12/17/11 08:25 AM
12/17/11 08:25 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Be careful on some of the "advice" given here on moparts. Please consult the factory service manual as to the proper procedure to tighten the rear suspension bolts.
MP HD springs are made in mexico and have quality issues.
You can effectively and safely lower the car by flipping the front spring hanger or better yet buying an adjustable one from Firm Feel. Do not use lowering blocks!
You may have too much spring rate with the xhd springs but that is a technicality at this point as i have no clue how big your wallet is.
Re: OEM HD Springs vs. AFCO XHD Springs - '72 B [Re: ThermoQuad] #1137513
12/17/11 09:21 AM
12/17/11 09:21 AM
IN
ahy Offline
ahy  Offline
IN
Agree its worth putting a couple hundred miles on the new springs. They will "settle" a little. I double checked the FSM and as several have posted, the spring bolts should be torqued with the weight of the vehicle on the springs.
I am runing the MOPAR XHD's. By design they are kinda low plus they seem like they drop more (sag) over time. Unless they have been improved, better to work with the ones you have. After some breakin if they are too high, consider taking them to a spring shop to get de-arched a little.
Re: OEM HD Springs vs. AFCO XHD Springs - '72 B [Re: ahy] #1137514
12/17/11 12:40 PM
12/17/11 12:40 PM
MassHole Central
rtman Offline OP
rtman  Offline OP
MassHole Central
These are AFCO 20231XHD. I drove it in with a used set of springs I bought off a board member. I may put those back on until I sort this out. I went with the AFCO XHDs when I read a post saying the MP repro OEM springs were Mexican junk and read a post by Dayclona recommending the AFCOs.
Later on I can consider messing with stuff like flipping the hangars or de-archuing the AFCOs. I think Jegs said they had a 5" arch. Can anyone confirm that?
Re: OEM HD Springs vs. AFCO XHD Springs - '72 B [Re: rtman] #1137515
12/17/11 04:54 PM
12/17/11 04:54 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Yep! 5" reference arch, car weight 3100-to-3500lbs, actual arch 6 5/8". Info at THIS LINK
Glad you bring this up. Heard some dissaponted with the MP XHDs. There are many options on the market for reproduction style XHD springs. What's the best rout to go?
New XHD "reporductions":
AFCO - www.afcoracing.com
ESPO - http://www.springsnthings.com
EATON Detroit Spring, Inc. - http://www.eatonsprings.com
Stock XHD spring rebuild kits:
Roger Gibson - http://www.rogergibsonautorestoration.com/index.htm
Re: OEM HD Springs vs. AFCO XHD Springs - '72 B [Re: CompSyn] #1137516
12/18/11 01:49 PM
12/18/11 01:49 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
You can't flip the front spring hanger, they only fit the car one way. The top studs are closer together then the bottom.
Be careful about some of the "advice" you get from board members.
Re: OEM HD Springs vs. AFCO XHD Springs - '72 B [Re: rtman] #1137517
12/18/11 02:16 PM
12/18/11 02:16 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
If they are still too high after setteling, find a local spring shop to de-arch them.
Re: OEM HD Springs vs. AFCO XHD Springs - '72 B [Re: scatpacktom] #1137518
12/19/11 12:16 AM
12/19/11 12:16 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
People do flip them by slotting the holes. I don't like it. I don't recommend it without reinforcing etc but people do it. AR makes multiposition front hangers and others have custom made their own.
It would be amusing if it wasn't so sad what the aftermarket sells as replacement parts. A look at the factory parts manual shows that Chrysler had many rear spring variations to match the various vehicles and option packages. For mass produced replacement springs, my experience has been with Triangle and Stanley Parts. The latter made a very good quality copy of the later FSJ springs. Number of leafs, lengths, thicknessess all correct with heavy formed clamps. Came through a regular supplyhouse. I have not yet followed up to see what they may have for our cars. I had Triangle's springs on the 'cuda. Nothing special replacement springs.
I am using circle track springs right now, but I also weighed the car front and rear, measured the old spring rates and ride heights and then did the calculations to get what I wanted. Not really what i would do for a street driver or restoration.
Re: OEM HD Springs vs. AFCO XHD Springs - '72 B [Re: 451Mopar] #1137519
12/19/11 07:44 PM
12/19/11 07:44 PM
IN
E
EricatAFCO Offline
EricatAFCO  Offline
E
IN
Guys, I would support the statements that leaf springs will settle some initially. The amount depends on weight of vehicle (on the rear tires) and rate of the spring. I too am not a fan of lowering blocks for street (and strip) use so if the car ends up sitting too high, consider taking to a local spring shop for some TLC to "adjust" the springs to your liking.
Re: OEM HD Springs vs. AFCO XHD Springs - '72 B [Re: EricatAFCO] #1137520
12/20/11 12:26 PM
12/20/11 12:26 PM
MassHole Central
rtman Offline OP
rtman  Offline OP
MassHole Central
Eric, do you have the measurements (eye to center, eye to eye) for my AFCO springs? Thanks.
Re: OEM HD Springs vs. AFCO XHD Springs - '72 B [Re: rtman] #1137521
12/20/11 01:53 PM
12/20/11 01:53 PM
IN
E
EricatAFCO Offline
EricatAFCO  Offline
E
IN
No problem. The spring measurements are as follows: center of eye to eye is 52 7/8". To measure from front eye to pin, we need to pull a string from center of eye to eye, then meausure from center of front eye along the string directly above the pin-don't follow the arch. This will give us our true measurements.
