How much sprayable paint needed to spray A body? #1137317
12/16/11 08:38 PM
12/16/11 08:38 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
How much sprayable single stage paint needed to paint an A body Barracuda? This is a color change so I will paint the jambs, engine compartment, trunk and outer body (I will not paint interior metal of car).
This is my first attempt at spraying a car so I will probably need to error on the conservative side.
5 quarts, 6 quarts, 8 quarts???
Re: How much sprayable paint needed to spray A body? [Re: VITC_GTX] #1137318
12/16/11 08:54 PM
12/16/11 08:54 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
when I painted, I bought a gallon of paint, 2 gallons of thinner.
a gallon to a gallon and a half went in the paint. the last half gallon was cleanup.
I am truckless..
Re: How much sprayable paint needed to spray A body? [Re: VITC_GTX] #1137319
12/16/11 09:33 PM
12/16/11 09:33 PM
Ohio
ralphie361 Offline
ralphie361  Offline
Ohio
What color and enamel, laquer, or urethane? Some colors need more coats to cover, and laquer is very thin and will need lots of coats (if you can still find it )
Re: How much sprayable paint needed to spray A body? [Re: ralphie361] #1137320
12/16/11 09:55 PM
12/16/11 09:55 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
I'm guessing he's going to use single stage polyurethane. This is what I've used so far on my Cuda.
Tip: use a primer that is light in color if your paint is going to be a light color.
Re: How much sprayable paint needed to spray A body? [Re: VITC_GTX] #1137321
12/16/11 11:54 PM
12/16/11 11:54 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The color you decide on makes a difference. Darker colors cover with fewer coats.
I've done color changes on almost every car that I have painted. The A body cars usually take about 3/4 of a gallon of what you refer to as "Sprayable" to cover the engine bay, door jambs and trunk. I've yet to repaint the undersides though. I've sprayed red, black, blue and white. Black covered in 2 coats. Red took 3. My next car will be Detonator Yellow. Its a very "tangy" shade. I'd resurrecting a derelict 74 Duster 360 and the factory GY3 was just too mild for me.
Re: How much sprayable paint needed to spray A body? [Re: VITC_GTX] #1137322
12/17/11 03:32 AM
12/17/11 03:32 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I'm thinking of going with red urethane (Summit brand). I wanted silver but am afraid to try metallic.
Re: How much sprayable paint needed to spray A body? [Re: VITC_GTX] #1137323
12/17/11 07:24 AM
12/17/11 07:24 AM
AZ
Mike P Offline
Mike P  Offline
AZ
Two big factors.....
Are you using a HVLP or old style siphon gun? With The HVLP more material goes on the car and less in the air so less paint is required.
Mixing ratio on the paint is also important. It’s not so much how much paint you buy, but how much sprayable paint you end up with. The ratio of thinner and hardener the paint requires can make a big difference in how far the paint actually goes. I was reminded of this the hard way the last car I painted.....I was trying a different paint and the amount of thinner and hardener required for this particular paint was a lot less than I was used to. I Barely had enough to finish the job.
I’ve been using SS Nason and SS Croma 1urethanes for the last few years and on those you need to cut and buff within 24 hours to get a good finish. If you let it sit longer it tends to haze when you buff it. I suspect the Summit may be the same way.
Just a suggestion but for a first paint job I would suggest maybe trying Nason Acrylic Enamel. It goes on nice and is pretty easy to work with. Like all the old enamels, you can drive it within 24 hours but it needs to cure for 90 days prior to buffing or waxing (the cutting and buffing window is indefinite after that).
Doing this the first time and including jambs, firewall, inside deck lid and hood, probably 6 quarts color plus the required reducer and hardener for a siphon gun (8 if you’re you plan on painting the fenders, doors and hood/deck lid off the car).
When you get the paint mix (especially if you go with Enamel and have it mixed locally) get a bucket and mix all the cans together to make sure you get a uniform color.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: How much sprayable paint needed to spray A body? [Re: Mike P] #1137324
12/17/11 10:37 AM
12/17/11 10:37 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
it depends on what color and type of paint you are using. sometimes when single stage color formulas are converted over to base coat. if there isn't a formula the mixer just mixes the single stage color then adds 50% more base coat binder to make it base coat color. needless to say you now have a color that has about 75% clear additives and only 25% tints. because of this coverage is rather poor to say the least.
when i do a job like what you are describing i order 2 gallons of paint with a extra empty gallon can. then intermix both gallons together so you have consistent color between the 2. now you won't risk running out of paint and have to order more paint that might not match, due to minor errors when the color is mixed.
the worse thing that can happen is you spend a few extra dollars and probably have some extra paint left over. if that happens get some empty quart or pint cans and pour the extra print in them to save it for another job. if the cans are full and sealed properly it can last a LONG time on the shelf. make sure it doesn't freeze and you will be good to go when you need it again.
perception is 90% of reality
Re: How much sprayable paint needed to spray A body? [Re: Mr T2U] #1137325
12/17/11 11:11 AM
12/17/11 11:11 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
...I pretty much said the same thing on the "F6 vs Snakeskin" color change post, have at least 2 gallons of sprayable paint on hand when doing the "whole" car, as it consumes a lot of paint jambing everything properly....always better to "throw away" paint, rather than a whole paint job, because you ran short, or that extra pint/quart you ran out to buy in a frenzy from the other store, because your paint supply guy was closed, didn't match, or had a bad reaction,...crap happens fast when your painting a car, you don't need the headaches of working with limited supplies on top of painting a car...regardless of what the paint costs
Re: How much sprayable paint needed to spray A body? [Re: VITC_GTX] #1137326
12/18/11 02:19 AM
12/18/11 02:19 AM
Jacksonville Florida
elitecustombody Offline
Buy 2 gallons to be on safe side ,that way you will have enough to get the job done and some paint leftover in case of a screw up or repair down the road. Use tintable sealer,it will take less paint and less time to paint.
Re: How much sprayable paint needed to spray A body? [Re: elitecustombody] #1137327
12/18/11 10:35 AM
12/18/11 10:35 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Two gallons of sprayable material,
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
