'69 bucket seat headrest question
#1135243
12/16/11 02:51 PM
12/16/11 02:51 PM
Posts: 1,228 Maple Valley, WA
70mopes
Maple Valley, WA
Were headrests std. on '69 bucket seat cars? I am doing my seats and found that the backs were dated right around the time the car would have been delivered... about a month after the time the car would have been built. Trying to figure it out. Maybe the car showed up without head rests, the customer complained and the dealer installed a pair of backs with headrests?? Anyway, the bases were dated correctly for the car and the tags matched left and right and the seat backs each had the same date on their respective tags albeit, with the later date.... Just looking for peace of mind.. Thanks
Re: '69 bucket seat headrest question
[Re: 70mopes]
#1135244
12/16/11 03:32 PM
12/16/11 03:32 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
Headrests were not standard on 69 Model Year cars until 1/1/69. They were optioanl on cars built Aug-Dec 1968.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: 70mopes]
#1135247
12/16/11 04:37 PM
12/16/11 04:37 PM
Posts: 8,940 Holly/MI
Dean_Kuzluzski
Holly/MI
Just curious, why would there be a month between when the car was built and when it was delivered??
Or do you mean ordered, then delivered?
Otherwise your theory could be right. I'd guess that it was something discovered at the plant, old stock shipped or mixed/dated inventory and then taken care of in the "repair" area at the end of the line after final inspection. A lot of that stuff goes on in an assembly plant. I have a 63 383 that is stamped coded as a "36", which is means it should be a 361!! Externally, they look the same. When stock gets low, stuff happens to keep the line running.
[Re: 70mopes]
#1135250
12/16/11 11:46 PM
12/16/11 11:46 PM
Posts: 18,423 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
The seats were replaced at some time in the cars life. Pretty simple answer.
[Re: 70mopes]
#1135252
12/17/11 05:12 PM
12/17/11 05:12 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
69 Head Rest topic covered in link. Chrysler TSBs included:
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=6634769&Main=6632692
My 69 Road Runner was built in September 68 so no head rests and no provision in the seat back either.
[Re: 70mopes]
#1135253
12/18/11 06:29 AM
12/18/11 06:29 AM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
I know my car was built during the last week of April. The tag on the seat backs are (I believe) the third week of May.
Is the car in question a 426 SPD A12 car? If so, what's the 6-digit number in the middle of the fender tag's top line?
[Re: 6bblgt]
#1135254
12/18/11 07:12 PM
12/18/11 07:12 PM
Posts: 2,601 Great White North
Furyman
Great White North
All the 68-69 upper seat frames are stamped for headrests.The most likely scenario is the headrests in your car were cracked,warped or disgusting looking and the last owner removed them ...seats recovered. Were any of the headrest nylon stops or guides still installed in the seat frames?
"Long Live Mopars"
[Re: Furyman]
#1135255
12/18/11 11:16 PM
12/18/11 11:16 PM
CompSyn
Pacific NW USA
That's not consistent with the Chrysler Technical Service Bulletin in the links I provided above so I'll post them again in jpg form.
1969 model year cars with production dates prior to December 1st 1968 had NO head rests and NO provision in the seat back frame to facilitate field installation.
1969 model year cars with production dates on or after December 1st 1968 had no head rests but did HAVE provision in the seat back frame to facilitate field installation.
[Re: CompSyn]
#1135258
12/18/11 11:41 PM
12/18/11 11:41 PM
Furyman
Great White North
Hi Anthony.All the upper seat frames were stamped...even the ones built in 1967 for the 68 model year.What the TSB is talking about is all the internal stops and guides etc.Looks like even if your late 68 built car was not equipped with the optional headrests it had all the hardware installed....except for the outside bezels and of course the headrests.Same deal with the 3rd tail light bulb in 69 Coronets.About a month prior to the new bumped tail light lense and 3 bulb housings the new tail lamp harness appeared.
"Long Live Mopars"
[Re: Furyman]
#1135259
12/19/11 02:13 AM
12/19/11 02:13 AM
CompSyn
Pacific NW USA
That makes more sense now. So since my car was built in September 1968, I'm only lacking the internal components to to install the headrests which I can install when I reupholster the seats. The seat backs will still accept the mentioned hardware even though not originally equipped. That's good to know because I would ultimately like headrests.
[Re: 70mopes]
#1135260
12/19/11 11:28 AM
12/19/11 11:28 AM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
hmmmm.... mine was a late april build. Wonder what other scenario might explain this....
There is no other scenario , some one removed them and it wasn't the factory or the dealer, headrests were a FEDERAL MANDATE .
[Re: 6bblgt]
#1135261
12/19/11 11:31 AM
12/19/11 11:31 AM
JohnRR
U.S.S.A.
Dan it's a 383 car.
