hotckis suspension question: e body. #1135193
12/16/11 01:25 PM
12/16/11 01:25 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I ordered the complete hotchkis suspension for my cuda.
I did order the rear leaf springs which lower the car 1"
i also have the complete front suspension stuff as well.
The question is: does the hotckis stuff alos make possible to lower the front suspension to match the rear suspension drop by just loosening the torsion bar or will it mess up the suspensions geometry?
Do you have to buy a 1" drop spindle elsewhere??? or is it no needed??
I tried calling hotchkis but nobody answers and the summit tech line doesnt know zip about this.
Re: hotckis suspension question: e body. [Re: domingo] #1135194
12/16/11 01:45 PM
12/16/11 01:45 PM
Q
Quicktree Offline
Quicktree  Offline
Q
why wouldn't you ask them first?
Re: hotckis suspension question: e body. [Re: Quicktree] #1135195
12/16/11 01:58 PM
12/16/11 01:58 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
they dont answer the phone....
is it a holiday up there???
same deal when i try to call 440 source...nobody answers.
Re: hotckis suspension question: e body. [Re: domingo] #1135196
12/16/11 06:09 PM
12/16/11 06:09 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
hotchkis tech line SUCKS. nobody answers.
Re: hotckis suspension question: e body. [Re: domingo] #1135197
12/16/11 06:18 PM
12/16/11 06:18 PM
Q
Quicktree Offline
Quicktree  Offline
Q
that sucks, but they could be out for the holidays. try talking to Fred he may be able to answer your question
Re: hotckis suspension question: e body. [Re: Quicktree] #1135198
12/16/11 06:19 PM
12/16/11 06:19 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
whats his nickname here at moparts? I dont remember it off hand...
Re: hotckis suspension question: e body. [Re: domingo] #1135199
12/16/11 06:42 PM
12/16/11 06:42 PM
Q
Quicktree Offline
Quicktree  Offline
Q
ummmmmmm hemifred
Re: hotckis suspension question: e body. [Re: Quicktree] #1135200
12/16/11 07:41 PM
12/16/11 07:41 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Oh you mean Fred Ristagno????
LOL
I thought it was the other member that I think works for Hotchkis and has an autocross dodge dart if im not mistaken!...
Re: hotckis suspension question: e body. [Re: domingo] #1135201
12/16/11 09:06 PM
12/16/11 09:06 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
to lower the front coil overs are the trick.They do not screw up the front end settings or handling Did you use their upper control arms also?
Hotchkiss is the only ones that I know of that have the bracket to reloate the upper A arm rear attachment point . This sets the plane of the A arm shaft to what would be parrell to the t bar. This helps eliminate the front end changes during travel.
home of the
Sox and Martin Hemi Duster
Re: hotckis suspension question: e body. [Re: domingo] #1135202
12/16/11 10:48 PM
12/16/11 10:48 PM
Aurora, Oh.
max_maniac Online happy
max_maniac  Online Happy
Aurora, Oh.
Email
Member # 51046
Name Hotchkis
Title member
Total Posts 193
Homepage http://www.hotchkis.net/index.html
Occupation High Performance Parts Manufacturer
Hobbies
Location Sante Fe Springs, CA
Bio
ICQ Number
Required - Moparts is all about what brand of cars? Mopars
Required - What made you to want to join moparts? community
Registered on Wed Sep 16 2009 11:35 AM
could try to use a PM as someone from there is a member here.
Re: hotckis suspension question: e body. [Re: HEMIFRED] #1135203
12/17/11 02:13 AM
12/17/11 02:13 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I thought the front end changes during suspension travel (bump steer) had more to do with the steering links following the same arc as the upper and lower suspension arms so that the steering linkage isnt pulled when the suspension travels up and down...causing the car to missalign throughout the suspension travel causing the steering on the car to wonder all around while the suspension travels.
I dont see how coil overs would do any better than a torsion bar for adjusting the height. The suspension components dont care if its a torsion bar or a coil over that holds the suspension at a certain level. nor if its a coil over or a torsion bar that makes the suspension travel a certain range...
the only way of lowering a front suspension without messing the concieved geometry and range of motion that it was designed to work at is by installing a dropped spindle.
what im asking is if, with the Hotchkis relocated upper A arm, the suspension was designed to work at factory height or at a 1" lower height than factory to work with the 1" lowered leafsprings that the Hotchkis TVS system comes with.
If the hotchkis system is designed to work at stock height, then in order to match the 1" lower height at the rear I will need to get some 1" dropped spindles.
I guess Ill just have to bolt on the front suspension , put the car in the air and see how bump steer reacts throughout the suspension travel....
or call Hotckis and ask, if they ever pick up the phone....
their website's FAQ doesnt say squat about this!
Re: hotckis suspension question: e body. [Re: domingo] #1135204
12/17/11 10:41 AM
12/17/11 10:41 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
Hotchkis has stated that the kit is designed with the favtory spindle. I don't see the need for drop spindle. I think it would be a good idea to check bump steer if you are able since ther is so much variation with these cars. The kit does come with different spacers to adjust the outer tie rod end height. I doubt most people check bump steer when installing their kits.
Re: hotckis suspension question: e body. [Re: domingo] #1135205
12/17/11 11:49 AM
12/17/11 11:49 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
if the upper A arm and lower arm do not travel on the same arc the path changes everything
My Duster has been changed and the front end reads exactly the same on the ground or in the air.
Coil overs allow the spring rate to be changed and set ride height still allowing full travel a tbar is limited
home of the
Re: hotckis suspension question: e body. [Re: domingo] #1135206
12/17/11 05:16 PM
12/17/11 05:16 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Yes, their system allows you to lower the front end via turning down the t-bars without creating a mess with the geometry. While droing the nose down this way will alter the geometry some, it will not "mess it up" so to speak, any worse than it was to begin with.
The biggest benefit to the Hotchkis layout is that it reduces dynamic caster changes during suspension cycling. THis creates a more linear change during bump which helps reduce some of the impact of bumpsteer that is inherent with the mopar design.
If they provide you the spacers to correct bumpsteer, definetly use them. You may not totally eliminate it with their kit, but it will help.
BTW, no one makes a 1" drop spindle that is widely available from retail vendors. I have seen 1" drops made from standard spindles and the 2" cast steel units that are sold through several reatilers, but that's it.
Re: hotckis suspension question: e body. [Re: TC@HP2] #1135207
12/18/11 05:05 PM
12/18/11 05:05 PM
Hotchkis Offline
Hotchkis  Offline
Domingo – Thanks for your purchase. Sorry you did not get an answer on the phone. Did you leave us a message? We were giving our employees a much-needed Holiday get-together break on Friday.
You can definitely lower the front suspension by adjusting the torsion bars without messing up the geometry when you’ve installed and adjusted everything to specification. In fact it's best to lower ride height by adjusting the torsion bars that's what we base our geometry design on. We suggest lowering the ride height. Stock ride height will work too, but lowering the car will get better weight transfer and center of gravity with optimal geometry. This is due to the Hotchkis adjustability and design which has incredible bump steer with less that 1/32 of and inch during suspension travel.
If you install an aftermarket spindle you could throw the geometry off.
http://www.youtube.com/watch?v=VzxPWrdPlt0
http://www.youtube.com/watch?v=FZX7jINa_ho
You can see how low our E-Max Challenger is with stock spindles.
These other two cars are using stock spindles and use torsion bar adjustments to lower the ride height and they perform and ride great!
http://www.youtube.com/watch?v=MQ_ja6nfVYw
http://www.youtube.com/watch?v=VX-B0AtfobA
Re: hotckis suspension question: e body. [Re: Hotchkis] #1135208
12/20/11 10:38 AM
12/20/11 10:38 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
thanks for the reply!
Re: hotckis suspension question: e body. [Re: domingo] #1135209
12/21/11 10:41 AM
12/21/11 10:41 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
When are you guys coming out with your own steering upgrades (hotchkis steering box and coupler)????
Re: hotckis suspension question: e body. [Re: domingo] #1135210
12/31/11 08:06 PM
12/31/11 08:06 PM
Hotchkis Offline
Hotchkis  Offline
Domingo – That’s a good question. We have been working diligently on suspension parts for many different applications that other manufacturers don’t produce. We’ve had great luck with the steering components we have on the E-Max Challenger (circle track style steering quickener in the column along with a Flaming River Box) and didn’t have to re-invent the wheel. If anything changes we'll definitely let everyone know.
http://www.popularhotrodding.com/feature...challenger.html
