Re: which 440 head would you buy??
[Re: ta70mopar]
#113500
09/01/08 03:44 PM
09/01/08 03:44 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
if I went w/ 915 would I have to worry about getting high enough octane fuel??
Is the short block already built? cause 8.7 compression without quench is more likely to detonate than a 10.0 engine with the advantage of quench...
[Re: 1_WILD_RT]
#113501
09/01/08 03:54 PM
09/01/08 03:54 PM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
Agreed. To take advantage of the 915's you'll need a decent amount of quench--and that means high compression (at least with flat tops) and MORE power. I would not go with 906's unless I already have them (and I do) or max power was not a concern. 10:1 on pump gas is easily attainable (and with a decent amount of advance), without the quench is tougher.
[Re: Pacnorthcuda]
#113502
09/01/08 04:29 PM
09/01/08 04:29 PM
#113503
09/01/08 04:44 PM
09/01/08 04:44 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
If you are not after really big power,I would suggest a worked set of 452 heads. Back-cut the valves,open up the bowls,do the portmatching.Plane them down 15-20 thou to keep a respectable compression ratio. They flow better than 906's and already have the hardened valve seats for today's corn swill we call gaz. They are more plentiful and cheaper compared to the highly desirable 915's Machine costs would be the same if not cheaper. Legendary Mopar engine builder Don Dulmage has proven that 452's are the better head. http://www.autohobbydigest.com/dulmage.html#ch10I am running a set of worked 452's on my 68 New Yorker.They were freebies and I spent under 800.00 getting them redone.The best money I spent,IMO.
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: DaytonaTurbo]
#113506
09/01/08 10:24 PM
09/01/08 10:24 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I would always go with a closed chamber head and build a quench engine with some flat top pistons and deck milling. Power wise, if they're both stock rebuilt heads they'd both make about the same amount of power. As for value, well 440source's stealth heads are $900, so to buy rebuilt stock heads unported with stock valve size, the price would have to be a heck of a lot lower than that.
Good advise. Ron
[Re: 383man]
#113507
09/01/08 11:13 PM
09/01/08 11:13 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
I like 915's and agree that with quench, that pump fuel will work up to 10:1 easily....The problem is, getting 10:1. If the 915's have been cut at all, you'll get more than that. With stock size manley valves, my 915's cc'd at 78. With .043 quench, and the valve reliefs in the speed pro's I'm a little over 10.6:1 I find it's a little much on pump gas, when I'm at sea level, but doable where I live (3600 ft) Camshaft becomes a variable here too, so there is a lot to consider. Run a 915 headed, quench 440, with a stockish cam, and I have no doubt it will ping like crazy. FWIW, I dismantled a 67HP 440 block, and the pistons were .067 in the hole.(plus .020 gasket and thats .087 quench area ) Quench wasn't a consideration for them back when they made them.
[Re: DaytonaTurbo]
#113508
09/01/08 11:20 PM
09/01/08 11:20 PM
Posts: 30,469 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
Have you or nayone else actually put some decent amount of "miles" on those 440S heads? Like to find out if the seats fall out or the heads crack or warp etc.
[Re: ta70mopar]
#113510
09/02/08 12:26 AM
09/02/08 12:26 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
no sending the short block out this week it was frooze got it free cylinder walls are kinda rusty i wonder how far they can bore them the engine is a 383 probley should have mentioned that thanks love this sight
Before you drop the engine off you really should take the time to know what you want before you get a typical generic overhaul treatment...
FWIW to get decent compression & quench with a 383 is gonna take custom pistons & that migt be more then you care to spend but I'll tell you do it right the first time cause you won't wanna go back & a few hundred dollars now won't matter in six months...
[Re: AndyF]
#113512
09/02/08 01:19 AM
09/02/08 01:19 AM
Posts: 48 New Zealand
Big-Mike
New Zealand
Mike in New Zealand here. I suggest saving your $$'s & buy a set of 440 Source Alloy's. I have some on a 440 Stroker(496)after running Hughes Engines Stage 2s & they run just as hard; ihaven't had them on the 1/4 yet, but my Australian Charger(3960lbs with me in it) does 12:0-12:25@117-118mph & a 60ft of 2:0 something every single run with 2:75 gears. Also does 17 mpg imperial which is about 19 US to the gallon. This is a 4-speed New-Process & Dual-Friction Center-Force Clutch. I have 10-1 comp: & 193 cranking pressure wwith a Comp-Cams 294 Solid.248@050:0.525 lift all on a 650 D/P. Weiand Xcelerator 7512, which is an old manifold & it pulls 6800rpm in 1st & 2nd gear. Almost 80 mph in 1st gear. Anyone wanting more info, just ask. Cheers, Mike
