Detune a Motor? #1134877
12/15/11 08:21 PM
12/15/11 08:21 PM
Shopping @ HoBo Fright
340SIX Offline OP
Doc Flappergas's Evil Twin
340SIX  Offline OP
I have a 340 that was built to much and was wondering what could be done to to detune it for street use or at least more liveable street use.
Virgin 340 X block bore is 4.040 stock stoke forged crank
With the flat top forged pistons that are in it with the small cc heads came in at 12.3-1 compression.
Aluminium heads 202/165 valves
Hdy cam that has like 230 something @50 with .504/.515 lift but has 1.6 rockers so .538/.549 to make the compression more liveable with a smaller cam
Auto hemi type fairbanks 11" stall that RPM matches cam{rebuilt by turboaction}
Reverse manual valve body in the 727 with 430 gears but have other sets
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Detune a Motor? [Re: 340SIX] #1134878
12/15/11 08:27 PM
12/15/11 08:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What's the cranking PSI ??? Looks like a nice pump gas engine to me if you built it right .
Re: Detune a Motor? [Re: 340SIX] #1134879
12/15/11 08:47 PM
12/15/11 08:47 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i'd run it the way it is. i'm street driving with more than that. by the way, lookin real good.
Re: Detune a Motor? [Re: 340SIX] #1134880
12/15/11 08:49 PM
12/15/11 08:49 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
What do you mean by "built too much"???
Is it a driveability issue??? Soft low-end throttle response?
What's been done to the mech. ignition curve??
What carb and carb tuning so far??
Typically many guys bolt on a carb and drop in the distributor, set total advance, and then the dissappointment begins when they want to street drive it.
Re: Detune a Motor? [Re: Dean_Kuzluzski] #1134881
12/15/11 09:31 PM
12/15/11 09:31 PM
340SIX Offline OP
340SIX  Offline OP
No car runs fine and leaves well with the gears and stall so seems matched right but have not driven it much as it was shown plenty but want to drive it
Stock 100% 340 auto carbs from holley for 340 six pack out the box starts up and runs fine.
Thing is the gas cost as I was running 100% 110 with lead for one high compression and 2 no problems with storage getting lines and carbs messed up from bad gas
So wondering how low I can go with octane etc...
Dist was set so it starts up fine and runs well that's all I know at this point.
I know I have to do a few things to get the kinks out as they never were addressed
Small oil leak at pan conner,
One water pump bolt leaks antifreeze and needs sealant Intake I think is sucking oil in from galley and needs pulled and milled and reinstalled as it sat to high on the commando heads
I never fooled with it as I had to rebuild a whole home ND THEN OTHER THINGS CAME UP SO CAR SAT.
would like to address those issiues and drive it if gas is not a large cost
Re: Detune a Motor? [Re: 340SIX] #1134882
12/15/11 09:43 PM
12/15/11 09:43 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Got E-85 ?
If you can get it then run it. You can have your carbs re-worked for it or buy a single 4 set up for it or do what I do and just use it like pump gas with NO CHANGES. I have done it for years and never had any problems. It is much less picky than gasoline about the fuel curve, it does like more timing though for sure.
Re: Detune a Motor? [Re: 340SIX] #1134883
12/15/11 09:56 PM
12/15/11 09:56 PM
Delray beach, Florida
P
Performance Only Offline
P
there's at least three things you could change to de-tune it, but i'd want to know the cranking compression on it before i suggested anything.
it sounds like you want to run pump gas, right?
machine shop owner and engine builder
Re: Detune a Motor? [Re: Performance Only] #1134884
12/15/11 10:52 PM
12/15/11 10:52 PM
340SIX Offline OP
340SIX  Offline OP
yes or a weak as i can do mix and still have it be ok
Re: Detune a Motor? [Re: 340SIX] #1134885
12/16/11 01:01 AM
12/16/11 01:01 AM
P
P
let me ask again if you don't mind; what is your current cranking compression?
Re: Detune a Motor? [Re: Performance Only] #1134886
12/16/11 09:56 PM
12/16/11 09:56 PM
340SIX Offline OP
340SIX  Offline OP
have not checked and tools are not here for doing that at my home right now.
Things are moving fast on my health issues, so looks like more test and meets with docs next week minor surgery. And Chemo soon after that so will just let the car sit more till that's over with.
Was thinking i had time to pull it down mill the intake fix a few things install full exhaust and use it some first.
Thanks for the responces
Re: Detune a Motor? [Re: 340SIX] #1134887
12/16/11 11:47 PM
12/16/11 11:47 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Good luck with your health isues
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Detune a Motor? [Re: 340SIX] #1134888
12/17/11 02:16 AM
12/17/11 02:16 AM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Kevin, get some Cometic Head Gaskets and drop your compression to whichever ratio you want...
you can order cometics in any thickness you need and they are suoper reliable, you wont blow them!
