Restricting bb rocker shaft oil (internal feed)? #1134777
12/15/11 06:43 PM
12/15/11 06:43 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
If you wanted to limit the flow of oil to the rocker shafts using OEM block & internal-oiling (OEM-style) heads, what would be the best way? Would you put some type of restrictor in the deck of the block? Would you drill & tap the head's oil feed passage to use a replaceable jet? Just looking for ideas, should the need arise. Thanks.
Re: Restricting bb rocker shaft oil (internal feed)? [Re: BradH] #1134778
12/15/11 07:03 PM
12/15/11 07:03 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Back in the old days we used to countersink and tap the oil passages for a holley jet...and some people use tubes that were just pressed and interference fit. They cant go anywhere.
And some guys put the restrictors in the block and others in the head, yet others (maybe the easiest way) just put the #4 cam bearing in off-centered over the valley passages...lots of ways to skin a cat.
WIZE
In Car:
Re: Restricting bb rocker shaft oil (internal feed)? [Re: BradH] #1134779
12/15/11 07:05 PM
12/15/11 07:05 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Engine builder I know does it with the cam bearing. Makes new hole in bearing the size he wants to restrict.
Getting old just means you were smarter than some and luckier than others.
Re: Restricting bb rocker shaft oil (internal feed)? [Re: BradH] #1134780
12/15/11 07:09 PM
12/15/11 07:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Since you are unsure if you will be reducing the flow
I would drill and tap the point just below where
the rocker shaft mounts, that would be the easiest
point to change the restriction (not having to pull
the heads to change it if it was in the block surface)
Re: Restricting bb rocker shaft oil (internal feed)? [Re: MR_P_BODY] #1134781
12/15/11 07:37 PM
12/15/11 07:37 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I agree with Mr.P on the where to put it. But I don't believe restricting the oil to the top end is a good idea for 99% of us. Heat is a big killer to valve springs and I would rather have all the oil I can get up there to keep them cool.
I would rather work on better ways to keep oil returning fast and off of the rotating assembly upon return than restict the oiling.
Keith
Re: Restricting bb rocker shaft oil (internal feed)? [Re: Dunnuck Racing] #1134782
12/15/11 07:45 PM
12/15/11 07:45 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
So long as you're not starving the bearings and the oil return is quick enough....I no longer worry about pumping too much up top. With the springs we run today the oil's surfactant qualities (their ability to wick away heat) is almost equally important as t otheir lubrication qualities.
WIZE
In Car:
Re: Restricting bb rocker shaft oil (internal feed)? [Re: Streetwize] #1134783
12/15/11 07:51 PM
12/15/11 07:51 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
x 99 on keeping-the-flow for the VS cooling.
Now if you want ... ...you can DIRECTLY "plumb" the drain-back oil from up-there back into the pan.
Re: Restricting bb rocker shaft oil (internal feed)? [Re: dOoC] #1134784
12/15/11 08:08 PM
12/15/11 08:08 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Brad did you see the mod that TrendZ posted. I really did like his idea. He positioned the cam bearing as to cut all the oil feed off of the cam bearing which would redirect that oil to the rods and mains. Then he drills a hole into the head feed galleys, both sides, then directly into the main oil galleys. The oil restriction would be how big a hole you drill into the main galleys. Then drill and tap your head feed galleys for plugs. Constant feed oil to heads straight off the main galley.
Re: Restricting bb rocker shaft oil (internal feed)? [Re: dannysbee] #1134785
12/15/11 08:32 PM
12/15/11 08:32 PM
Central Pa. U.S.A.
Bigfury Offline
Bigfury  Offline
Central Pa. U.S.A.
What kind of ideas is there for returning more oil away from the crank???? Like some kind of drain from the rear of the head to the pan?
Re: Restricting bb rocker shaft oil (internal feed)? [Re: Bigfury] #1134786
12/15/11 08:36 PM
12/15/11 08:36 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
JUST what I said at 5:51 ...
Re: Restricting bb rocker shaft oil (internal feed)? [Re: dOoC] #1134787
12/15/11 08:59 PM
12/15/11 08:59 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
if you look at the cam bearings hole alignment to the block passage and the design of the oil passages in the #4 cam journal the factory design already has restriction built into it. keep in mind that the #4 cam journal's oil passages only have a brief alignment with the block passage every 720 degrees of crankshaft rotation.
Re: Restricting bb rocker shaft oil (internal feed)? [Re: BradH] #1134788
12/16/11 12:53 AM
12/16/11 12:53 AM
Cab_Burge Online work
Cab_Burge  Online Work
I like to oil the rockers full time first and then use a .040 restrictor in the oil feed to the rockers, head or block, both work
Re: Restricting bb rocker shaft oil (internal feed)? [Re: Cab_Burge] #1134789
12/16/11 11:33 AM
12/16/11 11:33 AM
BradH Offline OP
BradH  Offline OP
Yeah, something like that. I've been getting my #4 cam journal's grooved for full-time oiling, but was thinking it might be helpful to be able to control the passage size actually feeding the rocker shafts.
Something on the "top half", rather than requiring the heads to be pulled to change, would certainly be better.
Re: Restricting bb rocker shaft oil (internal feed)? [Re: BradH] #1134790
12/16/11 01:11 PM
12/16/11 01:11 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
it looks to me that a roll pin type sleeve could be pushed in the passage down from the shaft side.
Re: Restricting bb rocker shaft oil (internal feed)? [Re: BradH] #1134791
12/16/11 01:16 PM
12/16/11 01:16 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Cab, are you using that .040 restriction on your street motors? I believe my small block is filling the valve covers on WOT runs and leaking out the breathers. I have erson needle bearing rockers and a grooved cam so it oils ALOT all the time. I have been considering restricting the oil some to see if it helps the bleeding breathers, it has good baffles already.
I was considering external drains but my block is tubed so the lifters oil off of the drain back.
68 Barracuda Formula S 340
Re: Restricting bb rocker shaft oil (internal feed)? [Re: Bad340fish] #1134792
12/16/11 03:18 PM
12/16/11 03:18 PM
I do the full time oiling on any motor that has a solid roller cam I do it for additional oiling and cooling to the valve springs I have seen several BB Mopars really flood the top end without retricting the feed
Re: Restricting bb rocker shaft oil (internal feed)? [Re: Cab_Burge] #1134793
12/16/11 06:47 PM
12/16/11 06:47 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
I have a 499/400 with full time oiling and I restricted the block with a .100 orfice and it still floods the top and goes out the breathers. I'm doing a .040 next
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: Restricting bb rocker shaft oil (internal feed)? [Re: BradH] #1134794
01/19/12 02:36 PM
01/19/12 02:36 PM
BradH Offline OP
BradH  Offline OP
Update - I'm looking at adding screw-in restrictors into the cast-in rocker shaft stands on my Victors. Should the restrictors be brass or stainless steel for this use? Brass would be easier to drill, but would stainless steel be better for anti-corrosion purposes?
Re: Restricting bb rocker shaft oil (internal feed)? [Re: BradH] #1134795
01/19/12 04:03 PM
01/19/12 04:03 PM
Brass is good
Re: Restricting bb rocker shaft oil (internal feed)? [Re: Cab_Burge] #1134796
01/19/12 05:06 PM
01/19/12 05:06 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i usually groove the cam and install .060" orifices in the heads. not sure if the victors are the same but iirc you can use a 1/4-20 (or is it 10-32) setscrew in the passage below the rocker stand. i think you can just tap the existing hole with a 1/4-20 tap. i do get a little weird about dissimilar metals and electrolysis but there shouldn't be any moisture there. i know guys do really cut back on the oil to the heads but you'll never catch me doing it. i've seen too much burned up rocker gear over the years.
