Twin Brown Wires At The Ballast
#1134548
12/15/11 12:26 PM
12/15/11 12:26 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
On a standard Chrysler 70's ignition setup, what are the twin brown wires at the ballast resistor? Is one for the CRANK and the other goes to the "+" side of the coil?
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Twin Brown Wires At The Ballast
[Re: YO7_A66]
#1134549
12/15/11 12:38 PM
12/15/11 12:38 PM
RapidRobert
As you know the one brown would be from the ign sw "ign2" start terminal. Can you trace out the other where it goes to? Does it look OE or added? What year/model are we working w?
[Re: RapidRobert]
#1134550
12/15/11 12:42 PM
12/15/11 12:42 PM
YO7_A66
Indiana
It is definately OE or part of the aftermarket electronic ignition setup. I have not traced it out. It gets buried inside of the harness. 70 Challenger with the electronic ignition upgrade.
[Re: YO7_A66]
#1134551
12/15/11 12:55 PM
12/15/11 12:55 PM
RapidRobert
Is this a Y1 or similar harness for the electronic ign addition? EDIT mymopar is showing only 1 brown to the downstream end then a black wire from there to coil positive pri
[Re: RapidRobert]
#1134552
12/15/11 01:04 PM
12/15/11 01:04 PM
YO7_A66
Indiana
It is the harness that came with the kit. Thanks
[Re: YO7_A66]
#1134553
12/15/11 01:13 PM
12/15/11 01:13 PM
RapidRobert
I've never used an add on conversion harness so myself I'd have to see where the other brown wire goes to at the other end of the loom. Been trying to think what else needs full 12V in crank only & nothing is jumping out at me.
[Re: RapidRobert]
#1134554
12/15/11 01:15 PM
12/15/11 01:15 PM
YO7_A66
Indiana
This is a picture of the area.
[Re: YO7_A66]
#1134555
12/15/11 01:24 PM
12/15/11 01:24 PM
RapidRobert
Definitely not OE, Yeah I'd have to either post if anyone knows that harness or eyeball the other end. What brand is it?
[Re: RapidRobert]
#1134556
12/15/11 01:35 PM
12/15/11 01:35 PM
YO7_A66
Indiana
It is a MP kit and I will try and trace it down tonight. I am tracking down an electrical issue after installing a MSD box. I left off this twin brown wire connector and the car still started. This means that the other brown wire that is wired into the MSD unit with my RUN (blue) wire is possibly the other end of this second brown wire. Thanks again.
[Re: RapidRobert]
#1134560
12/15/11 09:01 PM
12/15/11 09:01 PM
YO7_A66
Indiana
I am currently trying to feed my MSD box with the 12v for run and the 12v for crank. So I took my blue wire (run) and my single brown wire (crank) and connected them together. The engine started and idled but my battery voltage was jumping all over the place and my ammeter was jumping around on the + side of the gauge. I then hooked up the two brown wires with the two above wires trying to fix the jumping voltage and both gauges acted the same as before. This is why I am trying to figure out what these twin brown wires are for. Tonight I made voltage checks on the blue/brown wires and I got 12v in CRANK and 12v in RUN just as I was expecting. What I was not expecting with the two brown wires was that they also showed 12v in CRANK and 12v in RUN. Now I am more confused about the twin brown wires and what their purpose is. If anyone knows why I am getting the voltage and ammeter gauges jumping around since I wired in the MSD box, that would be great news. Thanks
[Re: mikemee1331]
#1134562
12/15/11 10:30 PM
12/15/11 10:30 PM
YO7_A66
Indiana
Mike, I am talking about the RED wire for the original "+" coil shown in this drawing (up, by the coil). Thanks
[Re: YO7_A66]
#1134563
12/15/11 10:32 PM
12/15/11 10:32 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Mike, I am talking about the RED wire for the "+" shown in this drawing (up, by the coil). Thanks
my bad....... and i've got my heavy red on the relay....long day, going to bed ![](/ubbthreads/images/graemlins/image_294343.gif)
[Re: mikemee1331]
#1134564
12/15/11 10:36 PM
12/15/11 10:36 PM
YO7_A66
Indiana
""I am talking about the RED wire for the original "+" coil shown in this drawing (up, by the coil).""
I am now second guessing what I have wired at this red wire. I wonder if I have too many wires at this connection. What do you guys think should be wired at the "original + coil"?
[Re: John_Kunkel]
#1134566
12/16/11 01:52 AM
12/16/11 01:52 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Yes, on the original dual ballast setup one of the brown wires is from the ign. switch IGN2 and the other goes to the coil +
Yep that is right. Ron
[Re: RapidRobert]
#1134567
12/16/11 08:58 AM
12/16/11 08:58 AM
YO7_A66
Indiana
""From the blue ign1 (run) circuit, in addition the "point" of the ECU pentastar (all a 4 pin ECU needs) plus the alt blue field wire plus the blue "sense" wire to voltage reg and if elec choke (as I was advised (on here) use the white domino bakelite choke current resistor/shutoff)"" - Blue "RUN" wire which is the voltage regulator wire (done) - Brown "START" wire (done) - Alternator Blue wire (I do not have hooked up and it should have a tracer) So it appears that I still need the Blue/Tracer alternator wire if I am understanding you correctly. Since the twin brown wires show 12v on both the START and the RUN, I am assuming that I can leave those off since I already have the START/RUN voltages from the brown and the blue wires.
EDIT: I currently have the "A" and the "B" hooked up to the MSD box. Now I need to find the "C" wire.
Thanks Thanks Robert.
