Engine Diaper?
#1134360
12/15/11 03:24 AM
12/15/11 03:24 AM
Posts: 501 ONTARIO,CANADA
604 Hemi GTX
ONTARIO,CANADA
Who's diaper and why? I'm going to put one on my engine and would like info on fit and finish. How did you measure them so they fit properly? Thanks for any and all info Kevin
Re: Engine Diaper?
[Re: 65dragnet]
#1134363
12/15/11 08:34 AM
12/15/11 08:34 AM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
Mine is fro DRE. It fits good....
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Engine Diaper?
[Re: Dartsport540]
#1134364
12/15/11 12:20 PM
12/15/11 12:20 PM
604 Hemi GTX
ONTARIO,CANADA
Only reason I'm asking is I need one for a center sump pan with an external pick up. I've seen pictures with a rear sump and external pick up. Thanks Kevin
Re: Engine Diaper?
[Re: 23T Hemmee]
#1134371
12/17/11 02:21 AM
12/17/11 02:21 AM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
I learned a lesson with diapers and would like to pass the info on to anyione considering buying one. The sportsman do not need to have a SFI certificatioon. That also translates into NHRA not having any spec or requirements as to design or construction materials. Like everyone else I decided to buy what the required diaper. I checked around and found a company that many people had used and seemed happy with the product. OK so I send a pattern and it comes back in a reasonable time and fit pretty good.One of my helpers installed it . Then about a month later I see something hanging under the car it was the diaper. One of the catches broke allowing the diaper to flap and melt on the header while a section hit the ground and got ripped up. It was then that I took the time to see what I had purchased. The catches are plastic the type a kid has on his school bag. The straps are made out of another man made material often seen on school bags and those things you wear around your waist to hold valubles. The diaper is made of some synthectic that melts just like nylon. It would shock me if the materials cost more than 5 or 10.00. I* can't post pics from the laptop but will first chance I get
Judging by what I spennt my money on this next5 one will be SFI Kevlar or a homemade one better material and metal latches.
home of the Sox and Martin Hemi Duster
Re: Engine Diaper?
[Re: 65dragnet]
#1134374
12/17/11 04:44 PM
12/17/11 04:44 PM
Posts: 1,361 Wild West
M_D
Wild West
I agree with 23T. The pan would be ok to keep drips off the garage or trailer floor. If the engine comes apart most of the oil and water will be violently expelled out the side(s) and the drip pan will likely not catch or contain much (even with an absorbent pad). When the mph is getting up there the turbulent air will really blow the liquids around.
Re: Engine Diaper?
[Re: M_D]
#1134377
12/17/11 10:07 PM
12/17/11 10:07 PM
Guitar Jones
I'm going to build a belly pan since my car is a chassis car. I don't run the big numbers and have never hurt an engine on the big end so I'm not real concerned, in fact even the two catastophic failures I have experienced in my lifetime (over 36 years) never put a drop of fluid on the track. Big horsepower engines may explode and shed parts and that's why they need a ballistic diaper but my junk doesn't do that and I would say that most cars running in the 8 to 9 second range aren't going to be shrapnel producers either, well unless they are Chevies or on nitrous.
Re: Engine Diaper?
[Re: Guitar Jones]
#1134378
12/18/11 12:15 AM
12/18/11 12:15 AM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
I have a DRE and a Taylor. The tube car has the DRE one and the stock front end car with the 99 Hemi has the Taylor one. I have also used a stroud one in the orange car when it had a Hemi in it. This is the stroud that was on the car when the Hemi let go in the orange car. I woudl not run a car this fast without one period. Not one drop of ANYTHING on the track... car in the traps at 155
