which HEMI heads #1134087
12/14/11 09:42 PM
12/14/11 09:42 PM
TN
SCATPACK 1 Offline OP
TN
If u were building a 572 HEMI to drag race in a 2800 lb car with auto and 4 link.
What heads would you run and why. Seriously looking at either the Stage 5 or the New Indy heads with the 2.40 intake valves
Old Geezer Racing
Re: which HEMI heads [Re: SCATPACK 1] #1134088
12/14/11 10:12 PM
12/14/11 10:12 PM
Sterling Heights, MI
MCHBOB Offline
MCHBOB  Offline
Hands down Stage 5 the castings are nice.
Re: which HEMI heads [Re: SCATPACK 1] #1134089
12/14/11 10:13 PM
12/14/11 10:13 PM
Orlando Florida
blown572dart Offline
Orlando Florida
Brads or AJ
Re: which HEMI heads [Re: blown572dart] #1134090
12/14/11 10:16 PM
12/14/11 10:16 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Brads or AJ
with turbos
Re: which HEMI heads [Re: blown572dart] #1134091
12/14/11 10:29 PM
12/14/11 10:29 PM
TN
TN
Brads or AJ
Didn't think either of those could b used as water heads. Aren't they both billet heads. Dont want to use any puffers, just NA.
Old Geezer Racing
Re: which HEMI heads [Re: MCHBOB] #1134092
12/15/11 12:10 AM
12/15/11 12:10 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
X2, but in the Millenium style with the exhaust valve rotated 2* so you can run the bigger intake valves. Also, I would go with the 10 bolt style for the larger intake ports. The sixteen bolt ones crowd the intake ports too much.
If considering Indy, then I would go with RA6 heads on a motor like that. They already have those features and they flow in the ball park of the Millenium heads.
The biggest advantage I see with the Stage V heads is the use of the T&D individual rockers like the SS guys run.
Re: which HEMI heads [Re: Dragula] #1134093
12/15/11 12:26 AM
12/15/11 12:26 AM
TN
TN
I did not know about the T&D rocker set up on Stage 5 heads. I thought all of the Stage 5 rockers used the regular Hemi shaft and stands. Do the Milleniums have a different set up cast into them?
Old Geezer Racing
Re: which HEMI heads [Re: SCATPACK 1] #1134094
12/15/11 02:43 AM
12/15/11 02:43 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Talk about overkill, you can get a set of the stageV big valve custom heads from Tim Banning and get him to cnc port them. Then you add the T&D's rockers to those or Rockerarms.com rockers. You are looking at 1500hp capable setup. Tim
Re: which HEMI heads [Re: SCATPACK 1] #1134095
12/15/11 10:16 AM
12/15/11 10:16 AM
Orlando Florida
Orlando Florida
Brads or AJ
Sorry it didn't say one way or the other if it had water.
with turbos
Yea a lot of guys out there running them with turbos.Smart A$$
J/K
Re: which HEMI heads [Re: Dragula] #1134096
12/15/11 02:45 PM
12/15/11 02:45 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I would go ONLY with Stage 5. Great company that stands behind what they make, and their casting are the best. But remember, the 10 bolt Millenium head requires a custom intake like a Hogans.
Re: which HEMI heads [Re: Mopar_Rich] #1134097
12/15/11 02:52 PM
12/15/11 02:52 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have a pair of Stage V's for my build (And yes with turbos).
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: which HEMI heads [Re: SCATPACK 1] #1134098
12/18/11 03:27 PM
12/18/11 03:27 PM
NY
B1duster Offline
B1duster  Offline
NY
What heads would you run and why. Seriously looking at either the Stage 5 or the ******New Indy heads with the 2.40 intake valves******
anyone use or have info on the new Indy 426 HiPo ????
Re: which HEMI heads [Re: SCATPACK 1] #1134099
12/18/11 03:30 PM
12/18/11 03:30 PM
SoCal
Brian Hafliger Offline
SoCal
Custom castings from Stage V. I'm a dealer if your interested...
Brian
Brian Hafliger
Re: which HEMI heads [Re: Brian Hafliger] #1134100
12/18/11 08:47 PM
12/18/11 08:47 PM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
Raised port Stage V heads.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: which HEMI heads [Re: astjp2] #1134101
12/18/11 10:17 PM
12/18/11 10:17 PM
That will run you $5000, $2500 for bare castings and $2500 for full machining. T&Ds apparently go for around $5000. Tim sells the Stainless rockers for around $3000.
Re: which HEMI heads [Re: SCATPACK 1] #1134102
12/18/11 11:35 PM
12/18/11 11:35 PM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
This post is available in double vision where drunk.
Re: which HEMI heads [Re: bwdst6] #1134103
12/21/11 03:18 AM
12/21/11 03:18 AM
NY
B1duster Offline
B1duster  Offline
NY
Re: which HEMI heads [Re: SCATPACK 1] #1134104
12/21/11 06:39 AM
12/21/11 06:39 AM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
i would not go with millenium heads they have prostock big chief ports,and only use GM prostock intake, valves are already insane 2.42 intakes with 6 inch stem, chambers are only 150 cc compared to 175cc on most. i would go with stage v raised port custom heads jobber is 2k bare 1k for valves,springs,cups,seals,retainers,bolts,gaskets, and 2.5k for complete roller setup with billet stands
MOPAR OR NO CAR
Re: which HEMI heads [Re: ] #1134105
12/21/11 11:24 AM
12/21/11 11:24 AM
pennsylvania, usa
David Barton Offline
pennsylvania, usa
Our T&D/Barton rockers are available for the Millennium head too and retail for $3,495.00
David Barton
Ray Barton Racing Engines
610-693-5700
