Vacuum Pump install pics? #1133942
12/14/11 10:32 AM
12/14/11 10:32 AM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
Could you all share pics of your Vacuum pump install pics on BB mopars? Just curious as to where people have picked up from on the engine, and where the vacuum regulator has been positioned?
Has anyone run one of the new Enhanced 4 Vane pump?
Thanks in Advance
Alan Jones
Re: Vacuum Pump install pics? [Re: LA360] #1133943
12/14/11 11:02 AM
12/14/11 11:02 AM
an8sec70cuda Offline
Not the greatest pic, but you can see it. Pump mounted to the motorplate. Drawing vacuum from the driver's side valve cover, catch tank mounted on the motorplate on the passenger's side. It's an Aerospace pump by the way.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: Vacuum Pump install pics? [Re: an8sec70cuda] #1133944
12/14/11 05:45 PM
12/14/11 05:45 PM
Lenox, MI
gj69charger Offline
gj69charger  Offline
Lenox, MI
I made the bracket coming off the water pump.
Re: Vacuum Pump install pics? [Re: gj69charger] #1133945
12/14/11 06:38 PM
12/14/11 06:38 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I have the enhanced 4 vane Moroso pump. I use a Star regulator that is adjustable and mounts on the pump. The theory is it is better to reduce the pull at the suction by allowing air in at the pump instead of pulling dirty air though the motor. The will help some with how much oil it will pull. I will get about 2 oz of oil per pass.
Re: Vacuum Pump install pics? [Re: Bigcube] #1133946
12/15/11 03:48 AM
12/15/11 03:48 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
