66-69 Bendix Disc Brakes- Unique vs. Common Components
#1133859
12/14/11 02:51 AM
12/14/11 02:51 AM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
Besides the rotor/caliper/brake pads, what other front suspension items are unique to this brake set up?
Are the spindles, UCAs and LCAs the same as drum brake for these years?
Thanks in advance.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: 66-69 Bendix Disc Brakes- Unique vs. Common Components
[Re: EWJ]
#1133860
12/14/11 10:02 AM
12/14/11 10:02 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
The upper and lower control arms will be the same. So, the spindles and then the caliper, rotors, etc are different. If you have a complete setup, you could swap them out...
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: EWJ]
#1133861
12/14/11 10:06 AM
12/14/11 10:06 AM
Posts: 21,456 It's a dry heat
gtx6970
It's a dry heat
what front suspension items are unique to this brake set up?
Spindles, rotors calipers, brake hoses and prop/dist valves are all unique to the disc brake system
spindles, rotors and calipers are 66-69 Bendix system B-body only
[Re: gtx6970]
#1133862
12/14/11 11:07 AM
12/14/11 11:07 AM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
Bill the distribution valve is the same disc or drum on the 66-69 B body , there is a valve added to the rear line on the disc brake cars.
[Re: JohnRR]
#1133863
12/14/11 11:28 AM
12/14/11 11:28 AM
EWJ
Back in NJ....
Thank you all for the input.
[Re: JohnRR]
#1133864
12/14/11 12:26 PM
12/14/11 12:26 PM
gtx6970
It's a dry heat
John, I didn't know that. Here are the valves btw, 1969 Charger thats an original Bendix disc brake car.
