compression ratio ? #1133743
12/14/11 12:44 AM
12/14/11 12:44 AM
s.e. michigan
top8x7b Offline OP
top8x7b  Offline OP
s.e. michigan
how do you figure compression ratio ? formula? i know what bore size is 4.375
stroke 3.75
deck 9.98
compression height 1.300
piston deck -.008
h/gskt .039
head cc 84 aluminum
flat top piston (wiseco)
engine is a 451 b engine with stealth heads
Re: compression ratio ? [Re: top8x7b] #1133744
12/14/11 12:58 AM
12/14/11 12:58 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Use one of the comp calculators on here. Ron
http://www.wallaceracing.com/Calculators.htm
Re: compression ratio ? [Re: top8x7b] #1133745
12/14/11 04:16 AM
12/14/11 04:16 AM
Cab_Burge Online work
Cab_Burge  Online Work
stroke 3.75
deck 9.98
piston deck -.008
h/gskt .039
head cc 84 aluminum
Do the pistons have valve reliefs, if so do you know the CC of them. We need that to get a accurate ratio, we need the bore size of the head gasket also
Re: compression ratio ? [Re: Cab_Burge] #1133746
12/14/11 11:19 PM
12/14/11 11:19 PM
s.e. michigan
top8x7b Offline OP
top8x7b  Offline OP
s.e. michigan
the pistons have reliefs ,total 10 cc ,the head gskt bore is 4.41
Re: compression ratio ? [Re: top8x7b] #1133747
12/14/11 11:38 PM
12/14/11 11:38 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I seriously doubt you have 10 cc valve reliefs in your flat top. Its more then likely 5 cc,s and your just doubleing it.
With that said and with a 5 cc figure along with your other info, around a 10 .174 or 10.2 comp.
Re: compression ratio ? [Re: Sport440] #1133748
12/14/11 11:43 PM
12/14/11 11:43 PM
Az
Crizila Offline
Crizila  Offline
Az
10.075:1
Fastest 300
Re: compression ratio ? [Re: top8x7b] #1133749
12/15/11 12:18 AM
12/15/11 12:18 AM
Unitred Machine(KB)on line calculator says 10.12 to 1 comp. ratio Good, safe pump gas combination
Re: compression ratio ? [Re: Cab_Burge] #1133750
12/15/11 12:23 AM
12/15/11 12:23 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Yep! Thats what I used, but @ 5cc 10.174
But a 5cc difference should be more then a .05 comp change. I,ll run the numbers again @ 10cc
EDIT, Yep, with 10cc Cab, I get 9.74 comp.
84cc head
5cc piston
4.375 bore
.008 deck
.039 gasket ht.
4.41 gasket diameter
3.75 stroke
= 10.174
add 5cc piston for a total of 10 cc = 9.74 comp @ United Machine KB.
Re: compression ratio ? [Re: Sport440] #1133751
12/15/11 12:46 AM
12/15/11 12:46 AM
Az
Crizila Offline
Crizila  Offline
Az
Could be 10 CC's.
Fastest 300
Re: compression ratio ? [Re: Crizila] #1133752
12/15/11 01:06 AM
12/15/11 01:06 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Crizila, yep those pistons would hit 10 cc or so.
Im betting the OP,s pistons arent like that, with 4 sided reliefs.
