plugs #1133463
12/13/11 07:53 PM
12/13/11 07:53 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
this a fairly new combo.im just gittin ready to fire it up when my bigs 1050 gets here.its 493 ci. rb, with sr heads and a roller cam about 640 ish lift,dont have the card.10.8 compression 2inch headers.i have a set of autolite plugs no.5224.does anyone have a similar combo that can tell me what plugs they have found to work best?thanks,AJ
Re: plugs [Re: bonefish] #1133464
12/17/11 11:21 PM
12/17/11 11:21 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I don`t use Autolite plugs so can`t help ya there but a #-6 ngk should get the job done.
Re: plugs [Re: bonefish] #1133465
12/18/11 05:07 AM
12/18/11 05:07 AM
I just finished dyno tesing a very similar motor and i used a set of Champion RC9YC for the race gas testing and some retracted gap fine electrode retracted gap race Champions C57 for the E 85 testing I bought some Autolite 3924 to use in it at the track but I haven't ran them in any motors yet I have used AR3911 and AR3910 as well as the Champion RC12YC and the RC9YC in my pump gas 518 C.I. low deck that is right at 10.8 to 1 compresion now, they all have worked well, I haven't found my favorite for that combination yet
Re: plugs [Re: Cab_Burge] #1133466
12/18/11 11:43 AM
12/18/11 11:43 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I run the Champion C59CX in mine and the Autolite AR3933 is the same heat range. Champion works great have not tried the Autolites yet.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
