HEMI HEADS OUT OF THE BOX #1133341
12/13/11 05:12 PM
12/13/11 05:12 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
WHO HAS FLOW NUMBERS FOR HEMI HEADS OUT OF THE BOX. SOMEONE TOLD ME THE 426 HP HEAD WAS ABOUT 430 OUT OF THE BOX I FIND THAT A LITTLE TOUGH TO BELIEVE.
Re: HEMI HEADS OUT OF THE BOX [Re: robnbird] #1133342
12/13/11 05:18 PM
12/13/11 05:18 PM
an8sec70cuda Offline
Seems like I recall the MP aluminum hemi replacement heads flow around 330 cfm (int) out the box. I may be wrong on that though.
My MP heads flowed 430 cfm after Modern Cyl. head got done CNC'ing them.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: HEMI HEADS OUT OF THE BOX [Re: an8sec70cuda] #1133343
12/13/11 05:35 PM
12/13/11 05:35 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
thanks I considered the mp but am leaning toward the stage five or the indy 426 hypo. but I would like to se some flow numbers.
Re: HEMI HEADS OUT OF THE BOX [Re: robnbird] #1133344
12/13/11 05:39 PM
12/13/11 05:39 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
My stageV's flowed 367@.600, they only had a little bit of bowl blending when the valves were installed. Tim
Re: HEMI HEADS OUT OF THE BOX [Re: astjp2] #1133345
12/13/11 06:32 PM
12/13/11 06:32 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
tim which stage 5 head was that and is that a head you use
Re: HEMI HEADS OUT OF THE BOX [Re: robnbird] #1133346
12/13/11 07:34 PM
12/13/11 07:34 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Indy 426-1's OOTB
Intake Flow numbers out of the box were:
0.1 = 75cfm
0.2 = 130
0.3 = 201
0.4 = 271
0.5 = 333
0.6 = 362
0.7 = 366
0.8 = 371
Re: HEMI HEADS OUT OF THE BOX [Re: Dragula] #1133347
12/13/11 08:17 PM
12/13/11 08:17 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
thats not to bad, thanks I don't know why these head mfg don't have a standing ootb listing.
Re: HEMI HEADS OUT OF THE BOX [Re: robnbird] #1133348
12/14/11 08:50 AM
12/14/11 08:50 AM
Dragula Offline
Dragula  Offline
An educated consumer is probably not their favorite customer, but Indy does publish theirs in their catalogue for most of their heads. Mine flow right around 400cfm now, and I will work on them a little more this winter.
Re: HEMI HEADS OUT OF THE BOX [Re: Dragula] #1133349
12/14/11 12:14 PM
12/14/11 12:14 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
here are #s from someones blog on the mp heads.i saved it as those are what i used and i just cleaned up the ports some.
