426 Hemi valve cover gaskets and spark plug tube orings
#1133185
12/13/11 02:12 AM
12/13/11 02:12 AM
Posts: 5,044 At a gas station near you
badblack68
We are nearing the end of our 426 Hemi rebuild and need some help. Is their a source for a quality re-useable type valve cover gasket for the 426 Hemi engine? Also, I need a set of good orings for the spark plug tubes. Thanks in advance for the help/advise.
Nobody gets in to see the wizard! Ain`t no way! Ain`t no how!
Re: 426 Hemi valve cover gaskets and spark plug tube orings
[Re: badblack68]
#1133194
12/14/11 11:00 AM
12/14/11 11:00 AM
Posts: 1,029 Southeast Virginia
68jim
Southeast Virginia
This is the other recent thread I started about the hemi tube O-rings. O-ring topic When you select your O-rings maybe try to get one of the metric sized (5mm x 30mm) and one #318 and test fit to see which one you like better. Personally, I liked the tighter fit of the #318. I swapped mine out last weekend and I was happy with the results. With this size though you will need to install the O-ring first over the tube then slide the tube down into the valve cover. I gave the final push using the palm of my hand to seat the O-ring. I use a small pair of channel locks with rubber caps on the end to pull it back out but duct tape on the tip of the jaws would probably work as well. I certainly don't want to take anything away from what Arruzza or any other Mopar vendors carry out there - just saying that this worked well for me... Jim
