426 Hemi valve cover gaskets and spark plug tube orings #1133185
12/13/11 02:12 AM
12/13/11 02:12 AM
At a gas station near you
badblack68 Offline OP
We are nearing the end of our 426 Hemi rebuild and need some help. Is their a source for a quality re-useable type valve cover gasket for the 426 Hemi engine? Also, I need a set of good orings for the spark plug tubes. Thanks in advance for the help/advise.
Nobody gets in to see the wizard!
Ain`t no way!
Ain`t no how!
Re: 426 Hemi valve cover gaskets and spark plug tube orings [Re: badblack68] #1133186
12/13/11 03:34 AM
12/13/11 03:34 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Superformance for the gaskets and the Orings you can get from Arruzza high performance. Tim
Re: 426 Hemi valve cover gaskets and spark plug tube orings [Re: astjp2] #1133187
12/13/11 08:56 AM
12/13/11 08:56 AM
Thanks! By chance, do you have any contact information for both of those folks?
Re: 426 Hemi valve cover gaskets and spark plug tube orings [Re: badblack68] #1133188
12/13/11 11:45 AM
12/13/11 11:45 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Re: 426 Hemi valve cover gaskets and spark plug tube orings [Re: JohnRR] #1133189
12/13/11 12:00 PM
12/13/11 12:00 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Thanks astjp2 and JohnRR
Yes I offer quality gaskets for the Hemi
If possible please contact me Toll Free @ 1-866-925-7855 and I can better assess your needs.
Greg
http://superformanceproducts.com/
Re: 426 Hemi valve cover gaskets and spark plug tube orings [Re: badblack68] #1133190
12/13/11 12:13 PM
12/13/11 12:13 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I just went through the O-ring deal with my hemi and found that if I used a #318 sized ring that it makes a good tight fit around the tube and a firm fit into the valve cover - I have no more leaks. I do not know the specs of the O-ring that Arruzza sells. I also came across a metric sized one that fits really good as well. If you go the Arruzza route please let me know what size they are using. O-rings at the local supply house were about 45 cents each. I use the Fel-Pro #1629 valve cover gasket, it has a thin steel core with two thin cork layers. I like the steel layer as it keeps the gasket from shifting around but I did notice that the fit wasn't 100% perfect with repro MP valve covers so I did need to shave off a little to make if fit perfect. More than likely it might have been the valve cover but just a heads up to dry fit it first. Last time I bought a set from Mancini they were almost $50. I haven't seen the reusable gasket - must be new???
Re: 426 Hemi valve cover gaskets and spark plug tube orings [Re: 68jim] #1133191
12/13/11 01:31 PM
12/13/11 01:31 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
Here is my helpful tip of the day. When installing sparkplug tubes put the O-ring into the valve cover first... then slightly oil the outside of the tube before inserting into the valve cover. If you do it the other way it tends to just push the valve cover down and distort it.
Re: 426 Hemi valve cover gaskets and spark plug tube orings [Re: hemi70se] #1133192
12/13/11 04:37 PM
12/13/11 04:37 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
The only way to do it.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: 426 Hemi valve cover gaskets and spark plug tube orings [Re: 68jim] #1133193
12/13/11 09:18 PM
12/13/11 09:18 PM
Thanks for posting your expirience. I`ve decided not to use the Arruzza orings. I`m not willing to pay $30.00+ shipping for 8 orings when I can buy orings locally for less than .50/ea. I will look into the #318 orings you used for your Hemi.
Ain`t no way!
Ain`t no how!
Re: 426 Hemi valve cover gaskets and spark plug tube orings [Re: badblack68] #1133194
12/14/11 11:00 AM
12/14/11 11:00 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
This is the other recent thread I started about the hemi tube O-rings.
O-ring topic
When you select your O-rings maybe try to get one of the metric sized (5mm x 30mm) and one #318 and test fit to see which one you like better. Personally, I liked the tighter fit of the #318. I swapped mine out last weekend and I was happy with the results. With this size though you will need to install the O-ring first over the tube then slide the tube down into the valve cover. I gave the final push using the palm of my hand to seat the O-ring. I use a small pair of channel locks with rubber caps on the end to pull it back out but duct tape on the tip of the jaws would probably work as well.
I certainly don't want to take anything away from what Arruzza or any other Mopar vendors carry out there - just saying that this worked well for me...
