Witch ballast resistor to get? #1133167
12/13/11 01:58 AM
12/13/11 01:58 AM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
I'm needin a new ballast resistor for my 72 Dart, it did have points, then I got mopar electronic ignition conversion kit that had a new 2 plug ballast resistor, so I installed it, but now I need a new one, but I see thers more then one to chose from out ther!
Do I need to get a serten one or can I just pick any 2 plug one the auto parts has for my car?
Re: Witch ballast resistor to get? [Re: Hoop] #1133168
12/13/11 10:36 AM
12/13/11 10:36 AM
the one with the MP chrome/orange kit has a nominal 1.25 ohms though you can get by with less sometimes quite a bit less & less ohms gives a hotter spark at the expense of longevity (within reason) & nothing is set in stone with this plus the new ones are not real close to their rated #. I'd say anything from .8 to 1.2 ish would work fine or even a bit less than .8 (.4-.6) esp if you carry a spare (ballast/coil) . Take your ohmmeter along with you & have your parts man set out what he has on the counter.
Re: Witch ballast resistor to get? [Re: Hoop] #1133169
12/13/11 08:26 PM
12/13/11 08:26 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
what coil do you use?
Re: Witch ballast resistor to get? [Re: mikemee1331] #1133170
12/13/11 11:30 PM
12/13/11 11:30 PM
Home of the Dart
cudarroger Offline
cudarroger  Offline
Home of the Dart
What is the resistance on the old 2 pin (points style) resister?
Re: Witch ballast resistor to get? [Re: cudarroger] #1133171
12/13/11 11:53 PM
12/13/11 11:53 PM
GA
roadrunninMark Offline
GA
this one -->
broom is stable, slight angle of attack
Re: Witch ballast resistor to get? [Re: cudarroger] #1133172
12/14/11 12:03 AM
12/14/11 12:03 AM
Alot of em change drastically over time always increasing. My orig /6 65 dart points one has 1.6 ohms
Re: Witch ballast resistor to get? [Re: RapidRobert] #1133173
12/15/11 12:37 AM
12/15/11 12:37 AM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
Thanks for the help everbody, I belive I'll go with ballast resistor O'reilly has! Yell I had a prob. with my dart not long ago with the starter stayin enganged after key off & it was smokin the the batt. post befour I got the post off, So I think I may have that fixed so far with another key switch, but it caused a over chargen prob., got a VR & fix some other stuff & I think I might have it fixed if I put a new ballast resistor on it, the ballast resistor on the car got over hot & burnt on bottom & steel has a burnt smell comin from wear its at when runnin! its reedin 1.9ohm, the batt. at this point is readin 12.73v off & 14.11v wall running!
Re: Witch ballast resistor to get? [Re: Hoop] #1133174
12/15/11 12:50 AM
12/15/11 12:50 AM
1.9 ohms on the ballast is way too high. Voltage readings are good. If you turn headlights/ac etc on at a fast idle what do you show at alt and at batt?
Re: Witch ballast resistor to get? [Re: Hoop] #1133175
12/15/11 05:37 AM
12/15/11 05:37 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The big Mallory ballast resistor with the screw terminals works good and I have never burn't one out. It comes with the spade terminal adaptors so you can still plug the original connectors onto it.
http://www.summitracing.com/parts/MAA-700/
Re: Witch ballast resistor to get? [Re: RapidRobert] #1133176
12/17/11 07:02 PM
12/17/11 07:02 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
Got me a new ballast resistor at O'reilly, it reeds 1.6 ohms, the smell is gone, but now I,m getting a little higher reedings on batt.
12.76v not running & 14.28v when running & today was also colder then last time I tested! So do you guys think thats to high or it may be ok?
Re: Witch ballast resistor to get? [Re: Hoop] #1133177
12/17/11 07:44 PM
12/17/11 07:44 PM
Your charging rate is pretty close but I would check it at a fast idle w AC/lites etc on. Your sacrificing some performance with that much ballast but if you cut that in half not sure if you'd feel it in the seat dyno (maybe) & you're good as is if you're ready to take a break from it.
Re: Witch ballast resistor to get? [Re: Hoop] #1133178
12/18/11 01:10 PM
12/18/11 01:10 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
as Robert said it's a tad higher than you really need but i seriously doubt you'll ever notice any difference in spark especially if you're using a half-way decent set of wires.
Re: Witch ballast resistor to get? [Re: mikemee1331] #1133179
12/18/11 03:20 PM
12/18/11 03:20 PM
Sterling Heights, Michigan 483...
daniel_depetro Offline
Since you have electronic ignition why not completely ditch the ballast resistor?
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
Re: Witch ballast resistor to get? [Re: Hoop] #1133180
12/18/11 04:29 PM
12/18/11 04:29 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Choice of ballast resistor value is dependent upon which coil you are running...
Many of the later aftermarket coils such as the Blaster series one can use a lower value (< 1 Ohms) and certain times it can be eliminated. If the coil is the OE Mopar one, you should use a ballast resistor..
The primary function of the ballast resistor is to limit current not input voltage to the coil. Also the ECU or ignition box plays a part depending upon its ON/OFF switching rate as well..
Just my $0.02..
Re: Witch ballast resistor to get? [Re: Sinitro] #1133181
12/18/11 04:40 PM
12/18/11 04:40 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Just my $0.02..
X2..........again
Re: Witch ballast resistor to get? [Re: mikemee1331] #1133182
12/19/11 10:10 PM
12/19/11 10:10 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
I did find a Mopar Performance Ballast Resistors 1.0ohms & it sead on the web site it was for orange ignition box, so its on the way in the mail!
Yell,reason I,m wondering is the alternator gauge is reedin barley high even after I took it for a test drive today up the road in back a short ways a cuple of times!
Wall running with lights on bright & heater on high at 1200 or 1300rpm batt. v. stayed about the same at 14,04v to 14.05v.
After settin for a day the votes are right on batt. chacked befour I started it today 12.58v
I just don't know way my alternator gauge won't settle in the center like it use to after it starts & runs for a min.
Re: Witch ballast resistor to get? [Re: Sinitro] #1133183
12/19/11 10:33 PM
12/19/11 10:33 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
Um, what coil I'm running, I put a BWD Select Coil on it back in summer from oreilly!
Re: Witch ballast resistor to get? [Re: Hoop] #1133184
12/19/11 11:03 PM
12/19/11 11:03 PM
(1) what did the alt "batt" stud show and the blue sense wire at the reg? (2) batt has bad cell. high resistance in wireing (hot side and ground side) bad VR, VR not grounded, internal alt/brush issue. Start with the batt, slo charge it overnight then find a garage with an old fashioned load tester or easier is borrow a known good batt from one of your other Mopars EDIT the overcharging is unrelated to your ballast choice and the prob started when there was the meltdown so something got fried
