Re: whats the best slicks and why
[Re: 383man]
#1132980
12/13/11 08:58 AM
12/13/11 08:58 AM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
I like Mickey Thompson's and they are the only brand I will run. I know a lot of time people under inflate them, Mickey's like more air pressure usually than any other brand.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: ALKYW5DART]
#1132981
12/13/11 09:30 AM
12/13/11 09:30 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Thats more of a personal thing with tires and the way the car is set up... I've run 3 different brands... M/T, Hoosier and Phoenix... I got the most passes out of the M/T... got the best 60' on the Hoosier with the Phoenix right there also( 1.19 60') but got less passes with the Hoosier and Phoenix... I can pretty much tell you how many passes are on the Hoosiers based on the 60' numbers... I get 25 passes at 1.19, then another 25 at 1.20, 25 at 1.21 and it will stay right around 1.21 to 1.22 till about 125 passes total, then it falls way off to like 1.26... I dont do the big burnout thing OTHER THAN the first burnout when new... even when I pull the tires off the tread surface has a good bit left but the side walls dont work for me any longer... and I use tubes on all of them
[Re: MR_P_BODY]
#1132982
12/13/11 12:21 PM
12/13/11 12:21 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Mr P how are the phoenix compared to the hoosier? Can you break it down like the hoosiers? Just curious as me and a friend always disagree on this, I am hoosier and he's phoenix.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: dartman366]
#1132984
12/13/11 12:44 PM
12/13/11 12:44 PM
Posts: 1,260 Netherlands
72Challenger
Netherlands
In my street / strip car I had way better traction with goodyear compared to Hoosier & MT's but as said it will all depends on personal taste and the car's setup. For me it's goodyear so far, also with the new car.
[Re: 1967dartgt]
#1132987
12/13/11 04:32 PM
12/13/11 04:32 PM
MR_P_BODY
To me they were almost the same tire... MAYBE the edge goes to the Hoosier but very close
[Re: MR_P_BODY]
#1132988
12/13/11 05:12 PM
12/13/11 05:12 PM
Posts: 2,509 PA
moparacer
PA
After last year I am a Phoenix guy.
M/T a close second.
Are Phoenix tires available now again?
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: ALKYW5DART]
#1132994
12/20/11 09:18 PM
12/20/11 09:18 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Phoenix now and Firestone before that.Phoenix is the same as the Firestones.I use Phoenix as they last a long time,are consistant and I've never had any problem with the car not being able to hook.
[Re: Chris2581]
#1132995
12/20/11 09:50 PM
12/20/11 09:50 PM
Posts: 2,177 ill
dennismopar73
ill
I have ran alot of mickey 't', like them alot the Hoosier we have run they work just as good, but when the go away they go fast, Goodyears never ran, 'stones' where good but very short life! Ran some old m & h, they where decent but inconsistant on hook.
