Gas tank filler neck restoration.....
#1132618
12/12/11 07:47 PM
12/12/11 07:47 PM
Posts: 417 Caledon, Ontario
smac77
Caledon, Ontario
How are you guys restoring gas tank filler necks ?? Zinc coating them? Will a caswell kit do the trick... or am I stuck bending over for the electroplater !
Thanks Shawn
Restoration, Sales and Canadian Distributor For: AMD Sheetmetal Wizzard Direct Fit, Bolt In Aluminum Radiators Legendary Interiors SSBC & Wilwood Brakes Control Freak Suspensions Fine lines Tubing and many more... www.macleanclassics.com
Re: Gas tank filler neck restoration.....
[Re: belv2vert66]
#1132620
12/12/11 08:09 PM
12/12/11 08:09 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
I did it myself. I cleaned it up as good as I could and used 40/ 60 tin and lead soldering to cover the whole tube. turned out pretty good. Ill have to post a picture of it later. I guess there is a company that will do it but I cant remember who? seems like it was around $40 to do it?
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
[Re: rayztoy]
#1132623
12/12/11 09:35 PM
12/12/11 09:35 PM
Posts: 4,115 MD
floyd
MD
Yep, Al does an awesome job...
Ditto!
[Re: floyd]
#1132624
12/22/11 01:05 PM
12/22/11 01:05 PM
smac77
Caledon, Ontario
The problem with sending mine to Al is the border... I'm in canada and sometimes customs can be a pain... especially when you're trying to cross a part without value for taxation...they get all "sqirrly" about why it's coming into the country... the delay and hassel isn't worth it.
Do you guys know if al is just zinc plating them ? I have a zinc kit here but wasn't sure if that process would work or hold up to the fuel inside the neck.
Kevin, I'm curious about the tin /lead solder idea... did you just use the same steps as you would laying solder on a body panel ? How has it held up? I guess a little extra lead in your fuel wouldn't be a bad thing !
[Re: NV69B7RR]
#1132628
12/23/11 12:28 PM
12/23/11 12:28 PM
Posts: 6,585 SE Pa.
LimeliteAero
SE Pa.
Limelite do you have picture of the finished product from Al?
