63 New Yorker wagon axle width? #1132416
12/12/11 01:56 PM
12/12/11 01:56 PM
West Newbury, MA
MOPAR_AMC_FAN Offline OP
West Newbury, MA
Anyone know the width of the axle in a 63 New Yorker wagon? I can find 65-up C-body and Pre-65 B-body, but no mention of a 63 C-body, wagon or not. Anyone?
Re: 63 New Yorker wagon axle width? [Re: MOPAR_AMC_FAN] #1132417
12/12/11 07:25 PM
12/12/11 07:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The '63 Chrysler has the same component dimensions as the '64 B-body, overall width is 60 7/8".
Re: 63 New Yorker wagon axle width? [Re: John_Kunkel] #1132418
12/13/11 11:00 AM
12/13/11 11:00 AM
West Newbury, MA
West Newbury, MA
Cooooooool! So, it looks like a 68-70 B-body axle would be pretty much a bolt in. The spring perch width appears to be the same and the new axle would only be about 1/2" difference in width. Sweet!
Thanks!
Re: 63 New Yorker wagon axle width? [Re: MOPAR_AMC_FAN] #1132419
12/13/11 11:02 AM
12/13/11 11:02 AM
You sound pumped
Re: 63 New Yorker wagon axle width? [Re: RapidRobert] #1132420
12/13/11 12:02 PM
12/13/11 12:02 PM
West Newbury, MA
West Newbury, MA
I am! Now I just need to get the car! DOH!
Re: 63 New Yorker wagon axle width? [Re: MOPAR_AMC_FAN] #1132421
12/13/11 12:05 PM
12/13/11 12:05 PM
You will, just takes time/money. I was surprised to see that kind of energy this early in the AM. I'm going back to sleep
Re: 63 New Yorker wagon axle width? [Re: MOPAR_AMC_FAN] #1132422
12/13/11 03:01 PM
12/13/11 03:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Nope...the Chrysler rear end has 46" spring pad spacing, the '68-'70 B-body is 44".
Re: 63 New Yorker wagon axle width? [Re: John_Kunkel] #1132423
12/13/11 03:26 PM
12/13/11 03:26 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Then it sounds like an E body housing could be the ticket.. Or use the B body & move the perches... Allows you to center the wheels better anyway...
Re: 63 New Yorker wagon axle width? [Re: 1_WILD_RT] #1132424
12/13/11 04:56 PM
12/13/11 04:56 PM
West Newbury, MA
West Newbury, MA
The info I saw on axle widths is:
'64 = 60 7/8" (Exc.Max Wedge)
'65-'67= 59 1/2"
'68-'70= 60 1/8"
So, wouldn't the 68-70 axle fit better?
Otherwise, I can handle moving the spring perches. Just thinking I'd like to remove and keep the original rear and replace it with one that has the later axles.
Just went back and checked and an E-body axle might fit the bill, too. It's less than an inch wider overall. But are they pricey being for an E-body?
Re: 63 New Yorker wagon axle width? [Re: MOPAR_AMC_FAN] #1132425
12/13/11 08:46 PM
12/13/11 08:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
"Better fit" and "bolt in" are two different things. Your original statement was "looks like a 68-70 B-body axle would be pretty much a bolt in"....it isn't due to perch width.
Re: 63 New Yorker wagon axle width? [Re: John_Kunkel] #1132426
12/13/11 09:07 PM
12/13/11 09:07 PM
West Newbury, MA
West Newbury, MA
When I said "bolt in", I meant that the 68-70 axle was close enough dimensionally to the original that it would bolt right in to the car. When you said "The '63 Chrysler has the same component dimensions as the '64 B-body, overall width is 60 7/8".", I assumed that meant that both axles (the 64 B-body and 63 C-body) had the same axle width and perch width. I was unaware that the B-body spring perches were 44" apart whereas the New Yorker in question is 46" apart.
For "better fit", I meant only axle width. The 68-70 seemed closer to the original measurement than the 65-67, but I don't think it would really matter either way as they're all so close. Although, the E-body axle might be more of a "bolt in" since the perches seem to be the same distance apart as the original axle.
Re: 63 New Yorker wagon axle width? [Re: MOPAR_AMC_FAN] #1132427
12/14/11 02:39 AM
12/14/11 02:39 AM
Under the big sky
stateline Offline
stateline  Offline
Under the big sky
Wont a 65-69 C body rearend bolt right in ??
Re: 63 New Yorker wagon axle width? [Re: stateline] #1132428
12/14/11 05:39 PM
12/14/11 05:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The '66-'69 C-body would be the logical choice, a true bolt-in. The E-body will likely need shims to correct the pinion angle.
Re: 63 New Yorker wagon axle width? [Re: John_Kunkel] #1132429
12/14/11 05:49 PM
12/14/11 05:49 PM
scratchnfotraction Offline
,I have now found a use for the 67 c-body housing/46" perch centers and 30" axles I have
Re: 63 New Yorker wagon axle width? [Re: scratchnfotraction] #1132430
12/14/11 09:58 PM
12/14/11 09:58 PM
West Newbury, MA
West Newbury, MA
I believe you would be correct on the 65-69 C-body axle. It's got the correct spring perch width and it's less than an inch wider. Didn't notice that. Sweet! I bet you can get those pretty cheap, too.
Thanks again, everyone!
