Re: 63 New Yorker wagon axle width?
[Re: MOPAR_AMC_FAN]
#1132417
12/12/11 07:25 PM
12/12/11 07:25 PM
Posts: 25,992 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The '63 Chrysler has the same component dimensions as the '64 B-body, overall width is 60 7/8".
[Re: MOPAR_AMC_FAN]
#1132421
12/13/11 12:05 PM
12/13/11 12:05 PM
RapidRobert
You will, just takes time/money. I was surprised to see that kind of energy this early in the AM. I'm going back to sleep
[Re: 1_WILD_RT]
#1132424
12/13/11 04:56 PM
12/13/11 04:56 PM
Posts: 597 West Newbury, MA
MOPAR_AMC_FAN
West Newbury, MA
The info I saw on axle widths is:
'64 = 60 7/8" (Exc.Max Wedge) '65-'67= 59 1/2" '68-'70= 60 1/8"
So, wouldn't the 68-70 axle fit better?
Otherwise, I can handle moving the spring perches. Just thinking I'd like to remove and keep the original rear and replace it with one that has the later axles.
Just went back and checked and an E-body axle might fit the bill, too. It's less than an inch wider overall. But are they pricey being for an E-body?
[Re: MOPAR_AMC_FAN]
#1132425
12/13/11 08:46 PM
12/13/11 08:46 PM
John_Kunkel
Rio Linda, CA
"Better fit" and "bolt in" are two different things. Your original statement was "looks like a 68-70 B-body axle would be pretty much a bolt in"....it isn't due to perch width.
[Re: John_Kunkel]
#1132426
12/13/11 09:07 PM
12/13/11 09:07 PM
MOPAR_AMC_FAN
West Newbury, MA
When I said "bolt in", I meant that the 68-70 axle was close enough dimensionally to the original that it would bolt right in to the car. When you said "The '63 Chrysler has the same component dimensions as the '64 B-body, overall width is 60 7/8".", I assumed that meant that both axles (the 64 B-body and 63 C-body) had the same axle width and perch width. I was unaware that the B-body spring perches were 44" apart whereas the New Yorker in question is 46" apart.
For "better fit", I meant only axle width. The 68-70 seemed closer to the original measurement than the 65-67, but I don't think it would really matter either way as they're all so close. Although, the E-body axle might be more of a "bolt in" since the perches seem to be the same distance apart as the original axle.
[Re: stateline]
#1132428
12/14/11 05:39 PM
12/14/11 05:39 PM
John_Kunkel
Rio Linda, CA
The '66-'69 C-body would be the logical choice, a true bolt-in. The E-body will likely need shims to correct the pinion angle.
[Re: John_Kunkel]
#1132429
12/14/11 05:49 PM
12/14/11 05:49 PM
Posts: 15,487 Florida
scratchnfotraction
,I have now found a use for the 67 c-body housing/46" perch centers and 30" axles I have
