340 Oil Filter clearance
#1132052
12/11/11 10:47 PM
12/11/11 10:47 PM
Posts: 1,300 Washington
19cuda73
Washington
Checking things out on the install prior to firing the motor my oil filter has about 1/4 clearane to the exhaust pipe is this normal on a 340. I do not have the adaptor on it just a standard straight installation.
1966 Charger 383 4 speed (Black with Red interior) 1973 Cuda 340 4 speed (Lemontwist) 1972 Corvette
Re: 340 Oil Filter clearance
[Re: 19cuda73]
#1132053
12/11/11 10:51 PM
12/11/11 10:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Looks like a short filter would clear alot better but that is real close
[Re: 19cuda73]
#1132054
12/12/11 12:43 AM
12/12/11 12:43 AM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
Make sure you can get it off. If you installed that exhaust after installing the filter, you might be in for a surprise. I couldn't run a long filter on my 340 with stock exhaust for that reason. I know I guy with a 90 degree adapter for sale that could help that situation.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: 471Magnum]
#1132055
12/12/11 01:41 AM
12/12/11 01:41 AM
19cuda73
Washington
Thanks guys I do have an adaptor may try it tomorrow or try and get the shorter filter
[Re: 19cuda73]
#1132056
12/12/11 01:46 AM
12/12/11 01:46 AM
MR_P_BODY
If you go with your 90* adapter see if the long filter will clear.... should
[Re: 19cuda73]
#1132057
12/12/11 02:01 AM
12/12/11 02:01 AM
Posts: 1,607 Western Washington
Sixgun
Western Washington
Napa/Wix #1068 is the shorter chrysler, 1515 is the big boy. (Just for reference,1085 is even shorter than the 1068 and also will fit if anyone needs it) C
[Re: MY340]
#1132059
12/12/11 10:06 AM
12/12/11 10:06 AM
Posts: 15,487 Florida
scratchnfotraction
I have run the skinny short filter(mini filter) from a 2.2 or ferd 3.0 engine for more clearance. about 1/2 the size round and about the same length as a short fat filter. maybe an option,I have run them on SB with headers for yrs with no problems.
[Re: BDW]
#1132063
12/12/11 11:09 PM
12/12/11 11:09 PM
scratchnfotraction
Many choices
and none are skinny like a mini fliter
i ran one for header clearance as the 90* adaptors are not that good on flow unless they are cleaned up and then drilled to 1/2' with a radius/blending on the turns.
the mini is a tad bigger round than the rubber gasket seal at the filter plate
those in the pic are short to long but all the same size round
and they are all FRAM filters
[Re: scratchnfotraction]
#1132064
12/13/11 12:32 AM
12/13/11 12:32 AM
19cuda73
Washington
Thanks for all the information. I bought the NAPA 1068 and now have nearly 3/4 inch gap, Looks better
