Thanks for the info., I'll take a closer look at the parts for part numbers. I have the standard calipers (not dual piston). The reason I think the front spindles/brakes are later B-body is because of the front brake hoses, I brought in an old hose to the local auto parts store and they found a match with the later B-body stuff (the hose attachment point to the caliper is a block with a hollow bolt as opposed to the hose with a threaded fitting that the '72 E-body should have). This set-up was already assembled when I got the car. Doesn't seem to be any issues with the rotor on the spindle. Only issue I can see is the previously mentioned fitment between the ball joint/spindle. I'll be taking a closer look at this as well.
**edit: ok, after reading through the links above, it looks like the previous owner installed the later B-body set-up on the car without changing out the spindles**
