Hard Starting fresh 440...need help.
#113150
08/31/08 06:24 PM
08/31/08 06:24 PM
Posts: 3,691 MO
cdp
MO
I'm having a hard time getting this 440 to turn over and start.
The engine is fresh and was running in the car before dissassembly for paint and resto.
Put the motor and trans back in with k-frame from underneath. Everything is new, including a new MP starter, a 750 CCA battery. New plugs, wires, distributor, hoses, belts, etc, etc, etc. Everything is new.
I pre-primed the motor, ran fuel into the carb and got a little spark, but this thing still cranks hard and pulls the battery down real quick. I friend suggested a bigger batter cable. Currently is a 4 gage, but I happen to have a 2 gage. The pos. cable does get hot, but all other wiring seems find.
This motor ran before with no problems.
Any suggestions?
We did try starting the car while hooked to jumper cables too.
Re: Hard Starting fresh 440...need help.
[Re: cdp]
#113154
08/31/08 07:22 PM
08/31/08 07:22 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
When you said "almost," did it fire-off at all (combustion) or just turn-over slowly?
With New Battery and Starter, unless the engine is mechanically-obstructed or excessively tight from a rebuild, it should rotate freely. You could pull the plugs and see how easily it rotates.
It could be small battery-cables or bad connections/grounding.
I had difficulty starting my 440 after it sat for 20-years. Oil-primed, new plugs, turned freely, rebuilt/primed carb, etc, but it wouldn't start/fire.
Turns out it was a problem with the Electronic-Ignition wiring that had come apart where it connected to the main wire loom.
I've seen engines not start because someone left a rag in the intake-manifold under the carb. Could be something small that's not quite right.
[Re: John426]
#113157
08/31/08 09:32 PM
08/31/08 09:32 PM
It's easy to tell if timing is part of the trouble--just pull and ground the coil wiere, and crank. If it cranks much easier, then back off the timing.
A cable getting HOT is a bad sign. This could be too small cable, cable that's really bad (partly corroded/ broken inside), a starter drawing too much current (bad windings or dragging bearings) or an engine that is just way too tight.
[Re: cdp]
#113160
09/01/08 12:08 AM
09/01/08 12:08 AM
RapidRobert
pull the plugs & crank it, it should turn fast & smooth. Lets narrow this down & see if it's a short block friction issue or a cranking(batt/cables/starter) problem.
