71-72 Charger Lower Steering Column Help #1131519
12/11/11 12:06 AM
12/11/11 12:06 AM
Western., NY
sco440 Offline OP
sco440  Offline OP
Western., NY
Rebuilding my 72 Charger floor shift steering column. Question; at the bottom of the column, there's a white plastic "seal" or "bushing" with 2 tabs holding it in the tube. The hole in the "seal" is much bigger than the shaft. Mine had broken tabs so I looked them up and found 3 types. One was an actual bearing inside white plastic with 2 screws. I also found exactly what I had but with or without a rubber seal. What should I get? My column tube doesn't have 2 holes for screws to hold actual metal bearings, so is this an aftermarket update?
The FSM doesn't have a picture of the lower part and only says that the floor shifter column is similar to column shifter
'72 Road Runner
'72 Dart Swinger 340
'12 Challenger R/T
Re: 71-72 Charger Lower Steering Column Help [Re: sco440] #1131520
12/11/11 01:52 AM
12/11/11 01:52 AM
Shoreline, Washington
72roadrunnergtx Offline
Ask these guys about kit# C28K, includes retainer and seal. No lower bearing, seal only for your app.
Themoparshop.com
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: 71-72 Charger Lower Steering Column Help [Re: 72roadrunnergtx] #1131521
12/11/11 10:45 AM
12/11/11 10:45 AM
Western., NY
sco440 Offline OP
sco440  Offline OP
Western., NY
'72 Road Runner
'12 Challenger R/T
