426 Hemi build want 600-650 hp any ideas. #1131492
12/11/11 12:02 AM
12/11/11 12:02 AM
Maryville tn
67coronetman Offline OP
Maryville tn
My friend is building a 426 hemi with stock stroke & only .030 over mild head work & intake to match the heads running a solid lift cam with ross pistons & manley rods what i want to know who out here can give real hemi combos that you have built that was still streetable on pump gas. We have the hemi books we wnt real world answer from you out here that have done it thanks for looking & any help.
Old car are me......
Re: 426 Hemi build want 600-650 hp any ideas. [Re: 67coronetman] #1131493
12/11/11 12:17 AM
12/11/11 12:17 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Contact Tim Banning at For Hemi's Only. Get his CNC ported stageV heads, Have him match the stageV intake, Roller cam, lifters with pushrod oiling, aftermarket roller rockers per his recommendations. Good Oiling system. I am building a 572 that runs on 85 octane and it will get around the same horsepower. Tim
Re: 426 Hemi build want 600-650 hp any ideas. [Re: astjp2] #1131494
12/11/11 01:09 AM
12/11/11 01:09 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Troy built a 472 with E-brock (MP) aluminum heads that very streetable. It's a Comp custom flat tappet with 112 centerline. He runs it with a Cross ram and 68 holley super stock carbs.
Starts awesome. I went with a 40 mile round trip with him today in it.
Here's video of it running. It's got cheapy glasspacks on it that dump down before the axle (as S/S where delivered that way).
**Note from the videos inside the car that it has NO factory undercoating and NO seam sealer at all and NO backseat and just a thin carboard trunk divider. Also does not have aircleaners or even hood in videos. Without the rear seat you get a lot of trunk and undercar noise. Especially with no undercoating and seam sealer.
http://www.youtube.com/watch?v=TDUcTidxlpg
http://www.youtube.com/watch?v=H9tYaB_D98Q
http://www.youtube.com/watch?v=tIrU5pen-54
http://www.youtube.com/watch?v=DzCXe5fk3Sc
Re: 426 Hemi build want 600-650 hp any ideas. [Re: autoxcuda] #1131495
12/11/11 01:19 AM
12/11/11 01:19 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Mine is well over +700 on pump gas, but the cam I use can be a pain in the a$$ on parts and its +.060 and a 4.15 stroke. My heads flow right around 400cfm, and it makes the hp and the torque, just the spring pressures can be a pain.
My engine builder has one that is 657hp and is street driven runs 11.1s in a very heavy street car on drag radials and has a very mild cam, good flowing heads, and we have been kicked off the track for only having a lap belt and going over 122mph on that 11.1 pass. It is also a 4.15 stroke crank motor displacing 477 cubes.
My only 426 +.030 made about 580-590hp and was very streetable. The best street intake we have tested to date is the Ray Barton single plane...and around a 950 carb. The cam and heads will cost more than the stroker crank to make the hp and torque your looking for. I suggest going the stroker route....
Re: 426 Hemi build want 600-650 hp any ideas. [Re: Dragula] #1131496
12/11/11 11:56 PM
12/11/11 11:56 PM
NASHVILLE
MAVERICKSHEMI Offline
NASHVILLE
stroke it. Better off
Re: 426 Hemi build want 600-650 hp any ideas. [Re: MAVERICKSHEMI] #1131497
12/12/11 03:13 AM
12/12/11 03:13 AM
USA
max Offline
super gas
max  Offline
super gas
USA
Re: 426 Hemi build want 600-650 hp any ideas. [Re: max] #1131498
12/12/11 11:39 AM
12/12/11 11:39 AM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
get hold of rich @ firecore wires (a moparts member and sponser) and get his combo and info. his car is close to 4000 lbs and he was clicking off 10.85s at norwalk this year @ the mopar event. i can't give you #s on mine but desk-top dyno said 625 hp. that's a .020 over 426 with stock stroke, mp alum heads with port clean up only with a crane hyd roller with 564 lift intake 555 lift exhaust (advertised lift, i got a little more with different ratio rockers), duration is 236 int and 240 ex @ 50. small 2" hedman headers with a new mp crossram and 2 holley 770 carbs. starts easy and other then idleing a bit high (900 rpm) it runs and drives nice. i but 450 miles on it from aug to oct and had very few issues. even got 9 mpg if i kept my foot out of it. most guys tend to think on a street car a single carb will make more hp. dave
Re: 426 Hemi build want 600-650 hp any ideas. [Re: 3ddart] #1131499
12/12/11 01:39 PM
12/12/11 01:39 PM
Maryville tn
Maryville tn
Thanks for the info this is what i am looking for my firend ( DON"T ) have the free cash to stroke it so he is leaving it all factory specs and getting the power other way but yet keeping the comp down for street gas i know someone out here has built one with all the motor parts i find it hard not to.!!
Re: 426 Hemi build want 600-650 hp any ideas. [Re: 3ddart] #1131500
12/12/11 01:40 PM
12/12/11 01:40 PM
Cement Under Ground
666 Offline
666  Offline
Cement Under Ground
From asking around my house hold on the hemi builds the conclusion was to purchase a longer stroke crank shaft. By using a bigger cubic inch motor you would only have to produce around 1.2 HP per cubic inch compared to 1.45 HP per cubic inch with a 426 cubes.This is a camparision of 426 CI to 500 CI. By making the motor even bigger this number could drop down near 1.1 HP per Cubic inch. One Hemi motor in the house hold is much like you have suggested 426 CI with a 30 over and a mild 580 solid lifter came shaft. It needed a lot more compression to produce the Power over 650 HP and also has to be spun much higher in the RPM range to produce this. Also suggested was to go with different Heads than stock cast irons heads if you plan on making the motor bigger. Stage V was the choice here and if you go that direction then porting is recommended and then performance intakes are the next step. If the car is NOT some OEM Gold trailer queen ,build a Hemi Motor that can have changes added to it for more horse power in the future. Stock Cast Iron sometimes limits this with new Technology in the future from Aftermarket sources.Also with bigger cubic inch Hemis it takes less compression to produce your wanted HP motor making the motor more livable on the street with gas out of the Pump.
Re: 426 Hemi build want 600-650 hp any ideas. [Re: 67coronetman] #1131501
12/12/11 02:35 PM
12/12/11 02:35 PM
I believe his is stroked to 528 if I am not mistaken. Getting 650 out of a stockish hemi will require some money in the heads and probably more than the typical stroker....But if you have all the parts, get a hold of Ray Barton, RBRE, Tim Banning, FHO, or one of the other real good hemi builders out there and pick their brains a little. I have seen 800hp out of a +.030" hemi, but at 12.5:1 and lots of cam and head flow. 650 is doable on pump, but not cheap. I ran a tunnel ram on my 600hp hemi on the street, and still do. They like to breath. I think my next one after this 484 is going to be a 604 monster...Saw one at the drags this year, just awesome.
Re: 426 Hemi build want 600-650 hp any ideas. [Re: 67coronetman] #1131502
12/13/11 06:57 PM
12/13/11 06:57 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
This one dynoed at 670 @ 6000 on pump gas. 525 stroker, marine intake, 750 Holleys (600 bowls for fit), Stage V heads, Engle K-8 Hyd (248 @50, 586 lift), callis bottom end, ross 10.5-1 60 over.
Re: 426 Hemi build want 600-650 hp any ideas. [Re: 3ddart] #1131503
12/13/11 07:23 PM
12/13/11 07:23 PM
I received a PM from him today, and his is a stroker hemi...His comes in at 472 cubes.
Re: 426 Hemi build want 600-650 hp any ideas. [Re: 67coronetman] #1131504
12/13/11 07:32 PM
12/13/11 07:32 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
I would tend to think it would be pretty hard to get 600 - 650hp out of a stock stroke street hemi while still being streetable and able to run on pump swill. A factory race hemi grossed out in the 550ish range with headers IIRC.
I think your friend needs to;
- pony up and stroke it
- give up being streetable and pump gas friendly
or
- lower hp expectations to something more reasonable; maybe 500 - 550hp
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 426 Hemi build want 600-650 hp any ideas. [Re: DPelletier] #1131505
12/13/11 10:06 PM
12/13/11 10:06 PM
Maryville tn
Maryville tn
If he could he would.!
I just don't see how he can't get that hp. ?? i have a 440 stock stroke .040 over stock crank & rods with cheap kb pistons & Indy SR head with a very mild port job M-1 intake no port work at all & 950 carb with a solid lift cam 282/292 & 540/559 lift with 1.6 Indy roller rockers & TTI headers and i am making 580 hp & Tq at the same & i had it Dynoed so its not a guess HP motor.!
*** So you are saying a hemi with better heads & bigger Valves better rod & pistons and a roller cam set up and head work & intake work with good headers won't out do mine. ?? ***
or
Re: 426 Hemi build want 600-650 hp any ideas. [Re: 67coronetman] #1131506
12/13/11 11:31 PM
12/13/11 11:31 PM
or
You can get the 650hp out of it, but your going to end up paying Barton or FHO for some work on the heads, and pony up for a roller cam that may or may not meet your criteria of streetable. The mild strokers get away with a mild solid cam and stock heads and make that number easily. My 484 is making about 100 more than that, is very streetable, but the cam tends to wear on the valve train parts..My engine builder went the reliable as the shop truck route on the cam with the same size engine as mine, 10:1 compression instead of my 11.6:1 and stock flowing heads, vs. my 400cfm heads, and he is right at 657hp at 484 cubes.
Re: 426 Hemi build want 600-650 hp any ideas. [Re: Dragula] #1131507
12/14/11 11:37 AM
12/14/11 11:37 AM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
67 coronetman: dragula is right as far as paying the piper, no free lunch, lol. if you compare the cost and work involved to get it through heads or cam (i had hours in clearencing the pushrod holes for the hyd roller) to the cost of a stroker crank and balancing, the crank is the way to go. i had my bottom end when i started the build so i used what i had . i did as much of the complete project myself as i could (it took me 9 years) so cost was a big factor and since it was going to be mainly a street car whatever hp it made was ok with me. that being said if i was doing it again i would go stroker and sell the standard crank and would make more power at a slight increase in price. dave
Re: 426 Hemi build want 600-650 hp any ideas. [Re: 3ddart] #1131508
12/14/11 12:30 PM
12/14/11 12:30 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
start with a megablock if possible, and a stroker crank 4,25" with small journal chevy rods and small pins.
You can build a 540 that way, or something a bit smaller if you decide not to max out the bore on the block.
Get some stage V cnc ported stock replacement heads.
Stock vanke ported intake manifold or a stage V dual inlive intake.
dual edelbrock carbs.
10,5: compression.
You can achieve what you want with a solid flat tappet cam, or maybe if you can go for a mild roller.
Re: 426 Hemi build want 600-650 hp any ideas. [Re: 67coronetman] #1131509
12/14/11 03:11 PM
12/14/11 03:11 PM
DPelletier Offline
DPelletier  Offline
or
Of course he can make his 600-650hp......but if he want's to make it out of a 426cu in engine running around 10:1 so he can use garbage fuel, it is going to have to be more radical than I would consider "streetable".....YOUR definition of streetable may be different.
in almost EVERY example given in this thread, the motor is larger than 426 cu in......because stroking it is the cheapest and easiest way to get the hp AND have the engine remain relatively tame.
Re: 426 Hemi build want 600-650 hp any ideas. [Re: Dragula] #1131510
12/14/11 03:13 PM
12/14/11 03:13 PM
DPelletier Offline
DPelletier  Offline
.....the voice of experience.
Re: 426 Hemi build want 600-650 hp any ideas. [Re: Dragula] #1131511
12/14/11 03:16 PM
12/14/11 03:16 PM
DPelletier Offline
DPelletier  Offline
[..My engine builder went the reliable as the shop truck route on the cam with the same size engine as mine, 10:1 compression instead of my 11.6:1 and stock flowing heads, vs. my 400cfm heads, and he is right at 657hp at 484 cubes.
more good info.
So 426/484 = .88 x 657 = 578hp out of a similarly built 426 (a little simplistic, but close enough).....makes perfect sense to me.
