Re: Added oil cooler, decreased oil pressure
[Re: oleman]
#1131156
12/10/11 03:42 PM
12/10/11 03:42 PM
RapidRobert
I think the 1st move would be to as you said open it up as something is malfunctioning to be effecting almost a 25% drop
[Re: oleman]
#1131157
12/10/11 03:46 PM
12/10/11 03:46 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I would say that the cooler has a greater restriction than you think it does... try jumping a hose around the cooler to see if your pressure comes back
[Re: CompSyn]
#1131162
12/10/11 06:02 PM
12/10/11 06:02 PM
Posts: 15,487 Florida
scratchnfotraction
IMHO,the large 10jic line is the pressure drop. need a HV pump to pump more volume to raise psi. I would reduce the line size to a 6jic max hope it has extra pan capacity for higher rpm
