Re: 99 Ram overhead console removal ?
[Re: 73rrak]
#1131148
12/10/11 04:34 PM
12/10/11 04:34 PM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
Sure, I'll try and help you. It's been a really long time since I had mine apart but I went and took some pictures, so give it a go:
First, flip open the garage-door opener cubby and you will see two clips in there. Squeeze them together and push in a little and then pull down. Be gentle with those clips because I broke one on mine.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#1131149
12/10/11 04:38 PM
12/10/11 04:38 PM
Posts: 6,003 Salem
Grizzly
Salem
Ok, next there are two sliding hooks that hold the overhead in back where the sunglasses cubby is. After you get the front clips released you can then slide the overhead towards you and it should come out.
Mo' Farts
[Re: Grizzly]
#1131150
12/10/11 04:40 PM
12/10/11 04:40 PM
Posts: 6,003 Salem
Grizzly
Salem
That should be it. It might be one of the switches that is broke or, it might be a "timer module".
Mo' Farts
[Re: Grizzly]
#1131151
12/10/11 04:43 PM
12/10/11 04:43 PM
Posts: 6,003 Salem
Grizzly
Salem
Let me know if that works for you, I'll be around the computer for rest of the day. Like I said, it's been awhile so I might have missed something.
I have the console here if you need any more pictures or have any questions.
Mo' Farts
