Factory Holes in Floor Pan #1131134
12/10/11 02:33 PM
12/10/11 02:33 PM
Ia
4spdana Offline OP
4spdana  Offline OP
Ia
what are all the holes for in the floor pan of our Mopar's?
Re: Factory Holes in Floor Pan [Re: 4spdana] #1131135
12/10/11 02:47 PM
12/10/11 02:47 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Draining off the various rust-proofing coatings...Seat mounts...fastener holes etc...
Re: Factory Holes in Floor Pan [Re: screamindriver] #1131136
12/10/11 02:59 PM
12/10/11 02:59 PM
Ia
4spdana Offline OP
4spdana  Offline OP
Ia
ok.....that makes sense , saw drip's on bottom of floor pan like body was maybe dipped in something
Re: Factory Holes in Floor Pan [Re: 4spdana] #1131137
12/10/11 03:02 PM
12/10/11 03:02 PM
Harrisburg, Pa.
Harrisburg, Pa.
Sure was...Actually submerged in a series of big vats...
Re: Factory Holes in Floor Pan [Re: screamindriver] #1131138
12/10/11 08:35 PM
12/10/11 08:35 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
the holes are locating holes for the framework that carrys the car through the automated welding process at the factory-yes they do perform other funtions later----and the freeze plug holes are for getting the sand out the block after it is cast--being a freezeplug was an after thought-bob
Re: Factory Holes in Floor Pan [Re: savoy64] #1131139
12/10/11 09:39 PM
12/10/11 09:39 PM
Ia
4spdana Offline OP
4spdana  Offline OP
Ia
Thanks, thats really cool
Re: Factory Holes in Floor Pan [Re: 4spdana] #1131140
12/10/11 09:50 PM
12/10/11 09:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah it was cool to watch the guys throw a section of
floor pan or firewall on the jig... they would lay the
part on pins that fit the holes so it could be welded
to the next section.. quite amazing to watch a car
be built from beginning to end when it drives off
the line
