Driveshaft length vs rear axle movement and ..... #1130916
12/10/11 01:23 AM
12/10/11 01:23 AM
Florida STAYcation
dOrk ! Offline OP
The village idiot's idiot
dOrk !  Offline OP
Florida STAYcation
U-joint life?
I am guessing that I might wind-up with a DS that is about 12" long if I go with a long-shaft 727(because I want to maintain FULL-AUTO shifting). With a decent set of SS-type springs ...and longer shocks ... will I be in the danger-zone of spitting-out DS's(because of radial U-joint angles) ?
ORE ...am I going to have to go with a aftermarket shortie kit on the trans ?
Re: Driveshaft length vs rear axle movement and ..... [Re: dOrk !] #1130917
12/10/11 01:28 AM
12/10/11 01:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Most likely its going to put the U-joint in bind being
that short of DS and SS springs... you would be way
better off with a 4 link in that set up
Re: Driveshaft length vs rear axle movement and ..... [Re: MR_P_BODY] #1130918
12/10/11 01:32 AM
12/10/11 01:32 AM
Florida STAYcation
dOrk ! Offline OP
dOrk !  Offline OP
Florida STAYcation
Hay Mike .... just for food-for-thought ... how much would a complete 4 link set up be?
Re: Driveshaft length vs rear axle movement and ..... [Re: dOrk !] #1130919
12/10/11 01:38 AM
12/10/11 01:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
About $300 if you make the bars yourself... I buy
the brackets for the rear and frame from S&W and buy
heims at summit or else where and cut and tap my
own tubing... if you need the front cross bars add
about another $100 or so(I bend my own)
EDIT
Add for coil over shocks... I went with Strange
Re: Driveshaft length vs rear axle movement and ..... [Re: MR_P_BODY] #1130920
12/10/11 01:43 AM
12/10/11 01:43 AM
Florida STAYcation
dOrk ! Offline OP
dOrk !  Offline OP
Florida STAYcation
I don't think my chassis-guy wants to build all that. He IS going to "build" the rear frame extensions ....
So what would be the cost on the bars, heims and shocks etc ?
Re: Driveshaft length vs rear axle movement and ..... [Re: dOrk !] #1130921
12/10/11 01:46 AM
12/10/11 01:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Go look at http://www.swracecars.com/ and see what you want
Re: Driveshaft length vs rear axle movement and ..... [Re: MR_P_BODY] #1130922
12/10/11 01:54 AM
12/10/11 01:54 AM
Florida STAYcation
dOrk ! Offline OP
dOrk !  Offline OP
Florida STAYcation
OK ...I will that ... but I am just looking for a ball-park at this point.
How much LESS axle movement is there in a 4link vs leaf-spring ...in order to be effective?
Re: Driveshaft length vs rear axle movement and ..... [Re: dOrk !] #1130923
12/10/11 02:03 AM
12/10/11 02:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Go look ... they offer cheaper and higher price...
the thing with a 4 link you can control how much
movement you want... if you go over or under the
anti squat line
Re: Driveshaft length vs rear axle movement and ..... [Re: MR_P_BODY] #1130924
12/10/11 04:29 AM
12/10/11 04:29 AM
Florida STAYcation
dOrk ! Offline OP
dOrk !  Offline OP
Florida STAYcation
I have NEVER run a 4 link ...but how do you control up-down movement ? ... if not with the shocks and coil-overs?
Re: Driveshaft length vs rear axle movement and ..... [Re: dOrk !] #1130925
12/10/11 09:26 AM
12/10/11 09:26 AM
gregsdart Offline
gregsdart  Offline
Doc, I would call Mark Williams or another driveshaft company to see what their take on a short driveshaft is before going forward. A four link will definately keep the u joints closer to the proper angles,provided you keep the I C long. My worry is the angle of the driveshaft that could result from suspension travel.
The other thing that comes to mind is if you have a lot of suspesion movement, you also will have a lot of travel at the trans yoke. Possible bind?
Re: Driveshaft length vs rear axle movement and ..... [Re: gregsdart] #1130926
12/10/11 12:38 PM
12/10/11 12:38 PM
K&Q va.
BIGBLOCK_KAT Offline
K&Q va.
I know once I got my set up right inland empire told me "3/4" was the
play fore and aft that was the best. I think originally I had a 1/2" more and they said it weakened the the u-joint 50%.
