Re: chassis gurues jump in
[Re: Deepockets]
#1130909
12/10/11 01:06 AM
12/10/11 01:06 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Video is the best way to check things out... how much front end travel... also you might want lighter T- bars to give you some more push upwards for a longer travel... if you thing it tops out on the upper arm bumpers cut them down to about 1/2" .... what rear shock settings are you using
[Re: MR_P_BODY]
#1130912
12/10/11 01:24 AM
12/10/11 01:24 AM
Posts: 939 glendora, ca.
Deepockets
glendora, ca.
front travel is 3-1/2 to 4" before contacting the snubbers. the shocks are set in the middle of its on the comp and rebound. tire pressure is 12 lbs. i have not tryed altering pressure. the rear extension i lossened 3 clicks with no change. there were some big tired cars that were hooking fine last night, just not mine.
[Re: Deepockets]
#1130914
12/10/11 01:37 AM
12/10/11 01:37 AM
Posts: 43,127 Bend,OR USA
Cab_Burge
I have my ladder bars in the lowest hole in the front mount and have treid from no clicks(full soft) on both settings to 4 clicks stiffer on both settings on my Strange double adjustable rear shocks, Koni SPA in front with six cylinder torsion bars. I have ran both bias ply and radials on the car, 727 with a low (2.77to 1 ratio)low gear set, 8 inch T/A race SS Hemi converter (not built for my car ) with 4.10 rear gears foot braking, 1.39 60 ft times best so far on a good track M/T Et Street 13.50x30x15 on twelve inch wide rims.
[Re: Deepockets]
#1130915
12/10/11 01:53 AM
12/10/11 01:53 AM
MR_P_BODY
How wide are your rims for the 11" tire... where is the front ladder bar at(angled down?) and what is your 60' now
